Topic: Eachine Pro58 flesanje sa Achille firmwareom (Read 10221 times) previous topic - next topic
Ovaj vrlo jeftin diversity prijemnik koji sam uzeo za FS google Eachine PRO58 RX Diversity (cca 23€) se moze flesati sa ST-LINK V2 programatorom (3€) sa Achille softverom (11 €) i dobije se sve ovo nize navedeno. Sve sam pribavio i to cu odradit ovih dana pa javim kak je proslo;-)
https://achillesfpv.eu/home/achille%cf%83-for-eachine-pro58/
Graphical user interface
  • On Screen Display OSD
  • Roll information Bar with Current module temperature, total diversities , Statistics.
  • Lap Timer , Fly with your goggles and record your laps simultaneously.
  • 620 Channels (5325-5945) ready to serve for entire 5.8 band.
  • ULTRA Search , +-4 MHZ auto tune on current frequency, more powerful and more precise with more than 5000 RSSI Reads in fractions of the second
  • Manual search Mhz by Mhz over the band. With single click is jumping over predefine freqs and by holding the up or down button fine tuning over each MHZ.
  • EVENT mode , Searching down all the 5.8 band in 2,5 seconds and keeps in memory only the running channels, then you can browse them one by one.
  • FAST mode , a very handy feature to find very fast a frequency or a band.
  • Favorite channels up to 10. You can Save predefine band channel or a custom frequency.
  • Band Scanner Can Scan amazing fast all the band , and by single click UP/Down can Deep scan the Area that been found with the highest RSSI +-20MHZ
  • Find Model , Add a patch Antenna to bottom RX (B) and point to the place that the drone might lost , the Graphic interface + buzzer will guide you
  • Kerveros Mode , its a revolutionary mode that can drift the B RX +-1MHZ and split in half the to RX and make them independent
  • Flip screen support
  • Factory Reset.
Odg: Eachine Pro58 flesanje sa Achille firmwareom
...nece me ti USB driveri:-(
Komp mi ne prepozna ST-link V2 programator nego ostane Unknown Device. Nema cak ni podatak vendora prijavljen. Za drivere kaze da nisu instalirani a kod updatea da koristi najnovije drivere ;-))
Probao sluzbene ST link drivere u svim varijantama. Probo na 3 kompa. Dva Win7 jedan XP. Probo i firmware uodate al kaze da ga ne pozna.
Narucio novi pa sljedeci pokusaj kad stigne :-[
Kad stavis sam programator njega prepoznaje? Možda USB nema dosta struje?
Driveri su potpisani ili moras uci u win bez navedenog?
Ne prepoznaje ni sam programator. Prije neki dan instalirao sam ST drivere radi F3 FC-a od Tiny7 droncica s kojima nije proradio ni droncic ni ST-link i onda "CP210x USB to UART Bridge VCP Drivers" s kojima je dronu konekcija proradila a ST-link je takodjer dao poruku da je instaliran i da se moze pocet koristiti (ali nisam iso provjeriti u device manager pa neznam jel se i tada prikazao kao Unknown Device).
Neznam sto to znaci da su driveri potpisani. Instalaciju sam prema uputama pokrenuo kao "run as Admin".
U medjuvremenu sam sve instalirano deinstalirao i pokusao ponovo vise puta.
Posto u device manageru taj unknown device nema niti podatak vendora pretpostavio sam da je osto bez firmvera ili da je hardverski nesto.
Receiver se uredno napaja preko ST-linka sto se vidi i na slici iznad pa pretpostavljam da USB port daje dovoljno struje.
Shift i Windows restart pa F7 nepotpisani driveri i probajte u drugom usb portu.
Probao sam sad iz safe moda i pokfenuo sa nepotpisani driveri na kucnom laptopu na koji do sad nisam spajao STlink (win7 32bit). Ustekao i cekao da sam instalira i opet unknown device. Zatim ga kao takvog deinstalirao i instalirao sluzbene ST drivere za 32bit win7 kao admin. Prikljucio i opet isto...
Sad sam ga raskopo i bio je unutra komadic tinola preko mm velicine koji se slobodno kotrljao ::)  Ko prvi sretne kineza nekog nek mu sljagu lupi.
Dizem ruke i cekam postara...
Rješeno;-)
Kupio sam jedan ST-Link programator preko Njuškala jer mi se nije dalo čekati naručeni sa ebay-a. Kad taj stigne ide u prodaju tu na forum a prodavat ću ga odma u paketu sa 820 i 240 ohma SMD otpornicima potrebnim za hardversku modifikaciju za dobivanje OSD-a.
Uglavnom procedura je kako je i opisano na Achille stranici.
Nafleša se firmware, očita se "product key", u sklopu plaćanja "licence" kod checkouta se navede taj product key u predviđena polja i za pola sata mi je stigo mail da je moj product key sadržan u svim sljedećim releasevima. Tada sam ponovo downloadao firmware i ponovio flešanje. Kada se rebootao tražio je kalibraciju koja se sastoji od pointanja praznih konektora prijamenika u VTX stavljen na 25mW udaljen 1m...
Tada sam izbacio 3 pin i nalemio ta dva SMD otpornika i komad žice prema uputama (nisu imali 240 Ohma pa sam u paralelu slemio dva komada of 470 Ohma). U Settings meniju sam odobrio OSD na ON i napravio kratki test. Sama slika sa Tiny7 mi više nema sitno mreškanje koje je bilo prisutno do sada. Ostale funkcije nisam probao ali nema razloga da ne rade prema opisu...
Sad kad su se slegli početni dojmovi moram reć da ipak ne vidim promjenu što se tiče kvalitete samog prijema. Mreškanje u slici je i dalje prisutno na Tiny7 dronjku ali to je radi filtracije napona na kameri dronjka a ne do goggli. OSD je super stvar jer sam inače bez diop3jskih noaočala jedva vidio šta ispisuje po displejčiću samog prijemnika a sada preko OSD-a je sve savršeno vidljivo i nemoram skidati goggle. Pretraživanje je brzo i jednostavno. Jučer sam upotrijebio i "Find my drone" opciju i stvarno je pomoglo kod nalaženja 75mm dronjka u travi- tj smjera u kojem treba tražiti.
Sve ovisi i o transmiteru... nije isto tramp, unify ili neki chungalunga za 10$...
Kvaliteta VTXa je svakako bitna jer ako mu kanali nisu na tocnim frekvencijama prijemnik se bori s time. Ovaj mu softver omogucuje da se "navuce" po frekvenciji malo gore/dolje i zadrzi se tocno na kanalu gdje je odaslan.Premalo sam koristio naocale da bi mogao potvrditi to sto stoji u specifikacijama al kad se negdje nadjem sa ekipom sa istim ocalama a drugim prijemnicima mozemo usporediti sa istim antenama.
Fora je i mjerenje vremena kad se rundaju krugovi ali to jos nisam isprobao jer se jos borim sa osnovama FPV acro letenja;-)
Dosta nas je već naručilo i čekamo ga (moj je na putu svaki dan treba doć)... ipak je nahajpan dosta a i pokazuje se da je s razlogom dobar odabir...
Update
Firmware update je od V1.4 dogurao do V1.7
Od primjetnih poboljšanja dodan % baterije očala i zvučni alarm ako baterija dropne ispod 20%
Dodan zvučni signal drone finderu pa se očale mogu na čelo dignut i gledat kud se hoda a navodit se samo po bipkanju
Poboljšan lap timer i još neke sitnice al to nisam probavao.
Kako se prijemnik fleša malomalo više ga ne vadim iz naočala da se ne patim s duplo ljepljivom trakom nego samo nalemim Clock i Data žice a masu krokodilkom zakačim na masu konektora antene pa prijemnik tokom flešanja napajam preko očala.
Evo ja flasho danas, jučer kupio btw. i baš gledam kak je dodano noviteta.. nisam stigao letit da probam ali fakat vrijedi fw te pare... i navodno nove polčke koje se naručuju ne dolaze sa pinovima za flashanje...
Ma opet ce se nac fora da se Tck i Data izvuku zice pa taman direkt sa procesora samo ce trebat dodatan trud za to.
Si slozio i OSD?
Sad gledo na stranjskom forumu ovo sto si reko- nekima lemna mjesta za flashanje dosla razbusena pa su morali zagrebati lak da dodju do bakrenih vodova ispod i na njih se na(ka)lemili...
Usporedni test VRX-a s koristenjem mjerne opreme i analitike:
Edit/ proveo je i test Part2 u kojem je pro58 najgore ocijenjen te najavio Part3 u kojem ce sve razjasnit;-)
http://www.youtube.com/watch?v=MqAJ3QVqZ4I
