Topic: alexmos kontroler i sajla video boli glava (Read 1816 times) previous topic - next topic
evo naleti sam na ovaj video oduševio me je lik, pa ako netko želi slagat gimbal i letjelicu sve ima tu :)
Talon V2 + DJI Naza + Alexmos + Gopro = Near Perfection
http://www.youtube.com/watch?feature=player_embedded&v=SQUQMTuWVNs#!
The addition of a YAW axis on the gimbal should make it close to Perfect.No Post Stabilization has been added.The Talon V2 arms have been cut to make a 400mm motor to motor Quadcopter. (Originally 550mm)I am using the following hardware:Frame: Talon V2Flight controller: DJI Naza V1 (Firmware 3.12)Motors: Tiger MT 2212-11 kv:1100Propellors: Gemfan 8x4.5 carbon/nylon mix (balanced)ESC: CarbonBird 18aBattery: Zippy Compact 3s 4000mah 25cFPV camera: CarbonBirdVideo Transmitter: 1.3ghz 400mwBrushless Gimbal Controller: Alexmos (Firmware 1.3)Brushless Gimbal: 2 Axis (Home Made)http://www.multirotorforums.com/showt...Camera: Gopro 3 Black (1080p 50fps, medium lens)Radio: JR DSX9 MK2 2.4G DSM2 TransmitterAUW: 1330 grams (My PVC T-Quad weighed 1475grams with the same setup, though with NTM 2826 1200kv motors)Hover time: 11 minutesFlight Time: 8 minutes
http://www.multirotorforums.com/showthread.php?11332-DIY-Brushless-Gimbal-with-Wire-Rope-Isolation
svaka čast :)
Odg: alexmos kontroler i sajla video boli glava
negdje sam naletio ali neznam gdje di ima detaljan opis kako napraviti ovaj antivibration sa sajlama
cini mi se odlicno rjesenje za vibracije
