Topic: Flysky fs-t6 vs Flysky fs-i6? (Read 35903 times) previous topic - next topic
Jel neko ima iskustva sa oba dve stanice? Dajte neki link gde mogu procirati review za FS-I6 stanicu. Uzeo bih je za sina jer ima telemetriju za baterije. Dali su prijemnici za FS-T6 kompatibilni sa FS-I6?
Pozdrav
Odg: Flysky fs-t6 vs Flysky fs-i6?
Koga interesuje novi model flysky fs-i6 ovde moze vidjeti review.
http://www.youtube.com/watch?v=6oFEAjIolEw
Ispada da afhds 2a protkol bolji od starijeg koji je imala flysky fs-t6. Tvrde da i ako je 4 aa baterija da ce domet biti bolji. Plus je sprema za telemetriju. U startu ima barej dojave napona bateriuje sa prijemnika.
Karakteristike:
Flysky releases its newest i6 6 channel transmitter. It uses less power to run, has better range, and quicker response. The new i6 is more efficient and powerful than before.[/size]The i6 control center looks clean and uncrowded, yet puts sticks, the programming keys and the rotary knobs and toggle switches within easy reach. The entire transmitter has shrunken in size and ergonomically designed for a better, easier grip, and balanced for easy neck strap use. The i6 is significantly lighter than its predecessors allowing less fatigue during longer flight adventures. The i6 case also features a large carry handle that makes it easier to manipulate. A built-in antenna prevents breakage and damage. Other features include a large backlight LCD screen. The i6 operates in the frequency range of 2.405 to 2.475GHz.This band has been divided into 142 independent channels, each radio system uses 16 different channels and 160 different types of hopping algorithm.This radio system uses a high gain and high quality multi directional antenna, it covers the whole frequency band. Associated with a high sensitivity receiver, this radio system guarantees a jamming free long range radio transmission.Each transmitter has a unique ID, when binding with a receiver, the receiver saves that unique ID and can accepts only data from the unique transmitter. This avoids picking another transmitter signal and dramatically increase interference immunity and safety.This radio system uses low power electronic components and sensitive receiver chip. The RF modulation uses intermittent signal thus reducing even more power consumption.AFHDS2A system has the automatic identification function, which can switch automatically current mode between single-way communication mode and two-way communication mode according to the customer needs.AFHDS2A has built-in multiple channel coding and error-correction, which improve the stability of the communication, reduce the error ratio and extend the reliable transmission distance.Features:• 6 channel 2.4ghz radio with telemetry capability• Dual Rate/Trims/Gear/Flap/Gyro Gain Adjust/Flight Mode/Throttle Hold/Hover Pitch Switches• Easy to use Programming & Navigation Buttons• Supports Heli/Standard Wing/Elevon/V-Tail• 20 Model Memory• 8 Character Model Name• Trainer port• Backlit LCD Screen displays real time transmitter and receiver voltage• 4 Stick Mode Selectable• Optional telemetry receivers and sensors available separatelyBasic Programming Functions:Dual RatesSub TrimTravel AdjustChannel ReverseSwash MixGyro SensitivityThrottle CurveMonitorPitch CurveThrottle HoldModel NameTimerFlySky - i6 Transmitter Specs:Frequency: 2.4ghz ISM Frequency RangeModulation: GFSKSpread Spectrum Mode: AFHDS 2A and AFHDSBand: 142Number of Frequency Channels: 20Output Power: 20dbmWorking Current: 100mAWorking Voltage: 1.5v x 4 AADimensions: 174x89x190mmWeight: 392gResolution: 1024 bitStick Mode: Mode 2 (Throttle Left)FlySky - i6 Receiver Specs:Channel: 6 Frequency: 2.4g ISM Frequency RangePower: 4.5V~6.6V/30maNet Weight: 6.4gDimensions: 40.4x21.1x7.35mmRequires:4 x AA Type Battery For Operation[/color]
Da ne otvaram novu temu kad ova već postoji, dali je netko kupio Flysky fs-i6, kakvo je iskustvo?
Meni samo sto nije stigla od Kine. Pisacu kada bude dosla. Pozz
ja imam fs t6 i meni je odlična, početnik sam pa mi odgovara jer ima jednostavan menu a i domet joj je dovoljan da jedva vidim zagija koliko ide daleko
Trebam jednom legi kupiti neku stanicu pa mi se ova učinila ok za pocetnika.
Sent from my GT-S5570 using Tapatalk 2
siguran sam da je i6 dobra isto
Ja sam je porucio zato sto ima telemetriju za bateriju. A to je super kada letis na padinu ili kacis termiku pa se zaboravis. Jedino da vidim koliko trosi transmiter baterije.
navodno troši manje nego moja t6, ja sam prošlu sezonu jednom zamjenio i ove još traju, meni treba 8 komada, duplo hehe
Pozz
Imam jedno pitanje u vezi Flysky fs-i6,
Kakva je za multirotore?
Pozz
Zasto ne bi bila dobra za multirotore. Kada je goli minimun za multirotore 4 kanala, ovde imas 6, sta znaci da je ok. Jedan kanal ide na AUX switch za svetlo ili kameru i to je to.
Nov sam. Nisam jos dobro upućen. Hvala
Negde procitao da se moze binding uraditi i sa WLtoys V911 i WLtoys V911 pro helicopterom. Onda samo kupis taj heli i to je to. Ne moras za njega da dokupujes i jos trasmiter. Isto vazi i za Flysky FS-T6 transmiter. Om\nda se za zimske dane zabavljas u kici. A transmiter za WLtoys V911 kosata cca 28 dolara.
WLtoys V911pro
Pozz
Ja sam taman u fazi kupovine stanice., jos se mislim koju da kupim.
