Topic: V-bar sa self-level funkcionalnosti (Read 3229 times) previous topic - next topic
Novosti iz Mikada:
http://shop.mikado-heli.de/Novelties-Rotor-Live-2015.htm?shop=k_mikado_e&SessionId=&a=catalog&t=7941&c=7941&p=7941
VBar NEO now with bailout feature
 VBar NEO will come to market in four varieties:
  • with integrated receiver for VBar Control
  • without receiver for use with other radio brands
  • both also available with additional, external sensor
VBar NEO is equipped with the latest sensor technology for flybarless as well as for the bailout feature.
 The additional external sensor should be used where a standard VBar Silverline would have been chosen. The sensors (silverline type) with ring technology are still preferable on models with high vibration levels.
 External sensors can be retrofitted any time. VBar NEO detects the external sensor and switches operating modes automatically. In case of a sensor failure, VBar NEO will fall back to the internal sensors, thus providing real redundancy and providing additional operational safety.
 The bailout feature works independently from the external sensor.
 VBar NEO can be set up using a VBar Control or a personal computer/laptop computer running MS Windows or MacOS.
 VBar NEO will be brought to market with the reasonably priced Express version of the VBar firmware and can be updated easily at any given time (e. g. with Pro version, bailout feature or new and exciting features to come).
 Update and registration processes will be much more straightforward, using the same VBar Control Manager tool already known from VBar Control. Featurs and Apps can be added easily through our App Store.
 Available April/May 2015
Outrage Fusion 50
Futaba T14SG
Odg: V-bar sa self-level funkcionalnosti
Najs, napokon :)
Ja se vec prebacio na Skookom odavno. Mikado je zbog transmitera kasnio sa novim featurima valjda 2 godine.
HeliCommand/BavarianDeamon/Spirit/Ikon - nemam pojma sam baljezgam/pitam - kaj nemaju svi ovi to isto?
Koliko vidim Jeti izlazi sa receiverom koji ima FBL+Cortex u sebi - sve se programira- telemetrira kroz stanicu. A ima i proximity senzor - kad se majčica zemlja previše približi - eject,eject.
Nemaju baš svi.
BavarianDEMON 3SX - da
BavarianDEMON 3X - ne
BavarianDEMON Cortex - wings only
BavarianDEMON RigidV.2 - da
Heli Command - sad je bavarianDEMON
Ikon - Da
Brain - Da
Skookum 540 - ne
Skookum 720 - da
V-bar - ne
mBeast - ne
Jeti - ne znam
Outrage Fusion 50
Futaba T14SG
 :) Danke!
