Topic: FPV250 Quad - I ja bi se raceao! (Read 64842 times) previous topic - next topic
Već skoro od početka godine, ja si svaki mjesec kupim neku sitnicu da si složim i quada, pa da se poigram i time, i napokon je došao i taj dan!
Većinom po preporuci yode (hvala!) dijelovi su slijedeći:
Frame: RCX H250CF PRO 3K
http://www.myrcmart.com/rcx-h250cf-pro-3k-fpv-quadcopter-3k-carbon-fiber-barebone-frame-p-8497.html
Motori: RCX H2206 2250KV
http://www.myrcmart.com/rcx-h2206-2250kv-multirotor-outrunner-brushless-motor-motion-balanced-p-8395.html
ESC-ovi: RCX 20A (Super Mini) (OPTO / BLHeli + Bootloader Enabled / 6g)
http://www.myrcmart.com/rcx-20a-super-mini-multirotor-brushless-esc-opto-blheli-firmware-6g-p-8786.html
6x4.5" 6045 + 6x4.5" 6045 (R) - kombinacija narančastih + zelenih
http://www.myrcmart.com/6x45-6045-counter-rotating-propellers-gm-series-cw-orange-4pcs-p-8109.html
http://www.myrcmart.com/6x45-6045-counter-rotating-propellers-gm-series-ccw-orange-4pcs-p-8110.html
FC: AfroFlight Naze32 Acro
http://www.hobbyking.com/hobbyking/store/__68630__AfroFlight_Naze32_Acro_AbuseMark_FunFly_Controller_Soldered_version_Vertical_Pin_.html
PDB: HobbyKing Mini Power Distribution Board
http://www.hobbyking.com/hobbyking/store/__56831__HobbyKing_Mini_Power_Distribution_Board.html
Reciever: Lemon Rx DSMX Compatible 6-Channel
http://www.lemon-rx.com/shop/index.php?route=product/product&path=72&product_id=122&sort=p.price&order=ASC
Evo nekoliko slikica slaganja:
[attach=2][attach=3]
Ispod FC-a sam stavio PDB:
[attach=4]
Ovako izgleda kompletiran:
[attach=5][attach=6]
Ovo su ESC-ovi:
[attach=7]
Ovo od ispod je BEC i noge koje su kao došle s frame-om. Nisam baš sretan s tim nogama, ima li za kupiti negdje neke gumene noge? :D
[attach=8]
Video TX sam za sada riješio ovako jer nemam kutni konektor... Ovo moram promijenit?
[attach=9]
Flight controller i PDB su ovako složeni:
[attach=10]
Reciever se nalazi iza kamere:
[attach=11]
Baterija se za sada ovako spaja... tu bih stavio fixni xt60 na frame kad budem siguran koju bateriju furati.
Da, to je još jedno pitanje... Sad je 2200 3S gore, da li staviti neku manju pa ih češće mijenjati? Što vi furate?
[attach=12]
Sa 2200mAh ima 612g:
[attach=13]
Slijedeći post sa armanjem i prvim paljenjem sa 100 pitanja :D
Odg: FPV250 Quad - I ja bi se raceao!
Tu ce video uskoro :)
welkom  :D
batku gurni cim vise otraga da ti cg bude u centru, inace bus imal problema u voznji  ;D
ruke su nazalost banana, imam taj frejm.. ali na zidu mi je kao suvenir ;D najvise ubijen frejm ikada, ruke sam custom napravio i od tada su sve 4 citave  ;D
antenu postavi drugacije jer ces ju otkinut pri crashu (makar ta antena ima koma signal)
e da, i taj bec obavezni tranu, ubiti dat cu ti jedan jako lagan i minijaturan pa ga zguraj unutra, jer ces i njega posijat vrlo vjerovatno  ;D
odi pogledaj u moj topic ''ironicna muli garaza'' pa vidi kak sam ja slkepao taj frejm
Odlicno izgleda, sretno s pilom! :)
@Bubi: Hvala, trebat ce mi!@Ironic: Procitao sam kompletan topic... imam samo 2 riječi: Ti si lud! - Svaka čast (ove dvije :)) Bad Bunny je daleeeko najjači :)
Koje antene preporučaš?
Evo i video prvog paljenja, kako nemam/ne znam nikog u RI da se igra sa 250 multijima, morat cu vas ovako tlacit!
http://www.youtube.com/watch?v=dok44N-ygyE
Čim ga armam 1 motor počinje se vrtjeti. Predpostavljam da je to do accelerometra, iako sam ga kalibrirao...? Kako da to riješim?
Zadnji lijevi motor ne radi jednako kao i ostali, kod davanja polaganog gasa zna doslovno stajati na mjestu što se vidi od 35 sec na dalje, pogotovo oko 1:15.
Esc calibration
Tak je,povezi naze na komp provjeri dal su ti svi kanali na sredini 1500,onda iskopcaj batku odi pod motor settings sve motore na full prikopcaj batku BIP i sve motore na nulu i rijesen problem.
eo buraz kasnije ti sve posaljem kak da napravis, malo sam u guzvici sada  :)
Evo kalibrirao sam esc-ove:
http://www.youtube.com/upload
primjetio sam da ako spustim minimum throttle na 1000 recimo tako da se motori ne vrte onda me onaj i dalje zeza. A ako dignem min throttle na 1050 recimo, onda sve radi savrseno nakon armanja.
1. put danas u zraku!
Mislim da su osnove u redu, ali primjetio sam da kada dajem gas sav se počne uvijati i tresti. Nemam nikakva iskustva, pa vas molim da bacite oko na video kako to izgleda. Tnx!
http://www.youtube.com/watch?v=k-zOUU6ODz8
Hm zuvk je cudan kao da je labavo nesto hehe, jesi pidove podesija?
Nisam, ne znam kako. Ne znam ni cemu sluze... Moze mala pomoc/link?
Previsoki D na pidovima, nemoj tako letit, skurit ces motore. Daj sliku trenutnih pidova
Ok,
postam cim dodjem doma, doma mi je quad. Tnx!
