Topic: Turnigy Grafenske baterije (Read 12754 times) previous topic - next topic
Uskoro (kroz mjesec do dva) na HobbyKingu ce se moci kupiti nov vrsta LiPo baterija.
Navodno kombinacija najboljeg od Lipo i LiFe.
Po speckama malo teze od LiPo baterija, ali zato ispod 20% gubitka kapaciteta i vrlo malo povecanje IR nakon 1000 ciklusa.
Zvuci dobro. Cijela rasprava i testovi na RCG
http://www.rcgroups.com/forums/showthread.php?t=2592234
Odg: Turnigy Grafenske baterije
Bice red nabavit koju pa da se proba  8)
Eto taman stavili.
Vrijeme da se pripremimo za novu sezonu :)
Prave batke za minije kad se puno ciklusa radi :D,samo kolko teze je pitanje
to su neke mrak batke kada šiping za jednu malu dođe...
Li-Po capacity: 1300 mAh
Your Total EU50.1
Standard Price EU56.39
Shipping Options
CROATIA
140x75x71mm 329g
Fedex Priority  EU33.82
UPS Express  EU41.82
Mora da ih se boje postari  ;D
Ja cekam da se pojave na EU skladistu.
Kad vise nista ne salju normalnom postom iz kine, sve preko dostavnih.
HK o Graphene baterijama:
Advantages over traditional Lipo batteries.
• Power density: 0.15-0.17kw/kg (5Ah-16Ah)
• Power density: 0.13-0.15kw/kg (1Ah-4.9Ah).
• Stable High pack voltage through duration of use.
• High discharge rate, giving more power under load.
Internal impedance can reach as low as 1.2mO compar
HK, prije par godina , kada je počeo prodavati "Nano-tech":
Advantages over traditional Lipoly batteries;
• Power density reaches 7.5 kw/kg.
• Less Voltage sag during high rate discharge, giving more power under load.
• Internal impedance can reach as low as 1.2mO compared to that of 3mO of a standard Lipoly.
• Greater thermal control, pack usually doesn’t exceed 60degC
Dakle zašto bi pušio uvijek iste fore: Nano tech, A-grade, pa onda Ultimate Nano tech, Bolt (one koje zovu LiHV), sada pak ove Graphene...predlažem da slijedeće budu Ultra-nano-graphene-precharged_turbo... :D
Hahahahha :D,ja se drzim zippya i ok su,ovo sve mi je bas tako,marketing.
Ajde ne pricajte gluposti dok niste probali...
Diogene sad cete jos tvrdit da NanoTech nisu bolje od "normalnih" baterija ili da su LiHv iste kao i obicne? Dajte decki....
Nisam testiral pa se nebi stel mesati :),samo velim kaj meni odgovara,a ko voli nek izvoli.
A čuj Damir nama dok se rejsamo s minijima batke traju cca 2-3mj tako da nije zgorega probavat nove kad dođu (bilo HK bilo negdje drugdje)... fluktuacija batki nam je fakat velika tako da i nismo na nekom gubitku jer su nam batke uz propove najpotrošnija roba.
Ja ću baš probat ove... bumo vidli ;)
EDIT: evo promijenio sam na 2-3 mjeseca ::)
Pa ove Grafenke i izgledaju kao batke za rejsanje, zar ne ?
Da točno tako ! I jedno i drugo !
Usput, molim dajete pročitajte ono kaj sam označio sa crvenom u prethodnom postu!
I da , ne kažem da sam pametniji od drugih, tj. kupiti ću taj graphene samo da vidim kaj je. Time je dakle HK i kod mene postigao ono što je htio.. :D :D .. kao i kod drugih: malo poboljšaju svojstva, pa ajde narode navali kupovati!
Ak ih uspijemo ulovit jer kolko vidim po ostalim forumima igrat će najbrži prst kad dođu na HK EU
