Topic: Futaba GY-701 uskoro (Read 1972 times) previous topic - next topic
Evo sa infinitija
Futaba 701 ziro izlazi uskoro.
Nasljednik legendarne 611-najstice
Ukratko:
- podrzava 760 servace i S.BUS
- ima governor u sebi (GV-1)
Kaze ovako:
It is similar with GY-611 gyro; the control box is separate with gyro  unit. Seems the GY-701 is much close with 520, not 611.
It also  supports 760us system and Futaba S.BUS.
 The big change is it integrates  governor into system. The rotor rpm can be setting via radio. The rpm  sensor has two different types, one is as same as GV-1. The second type  will build on the engine cover (Not yet decided).
Anticipated sale date  is June. The price will be Japan Yan 28000.
Slikice
Odg: Futaba GY-701 uskoro
Evo nekaj za mene  ;D
Bit će preblizu cijene FBL elektronike!
Outrage Fusion 50
Futaba T14SG
