Tiny whoop (Blade inductrix upgraded) August 20, 2016, 04:51:49 pm Eto, pošto vidim da bi moglo biti zainteresiranih, da podjelim što znam. Stvar je super, pogotovo za hladne i kišne dane kada nije ugodno ili sigurno biti vani. Za jurit po doma ili uredu je neopisiv fun. (fyi, ima horizon i acro mode )Slike kako to čudo izgleda:[attach=1][attach=2]Što napraviti sa tiny whoop? Pa zabavljati sve oko sebe. DVR Video (by sekile) sa jučeranjeg guštanja. Nije skidao osmjeh s lica.(tiny whoop počinje na 40s videa)YouTube video:Što vam treba za jedan?Inductrix kao kit:https://newbeedrone.com/collections/beeductrix-inductrixUšteda cca, 20 dolara, vjerojatno i više ako se uzmu poštarine naručivanja sa minimalno 2-3 lokacije.Zanimljivo za vidjeti da ima i zamjenski clean/beta/flight kompatibilan kontroler.https://newbeedrone.com/collections/beeductrix-inductrix/products/the-beebrain-v-1-cleanflight-betaflight-compatible-flight-control-for-the-beeductrix-inductrix-quadZa prave profesionalce, ima i jačih frejmova: https://tinywhoop.com/collections/all/products/rakon-frame-for-the-tiny-whoop?variant=22579419457Moj orginalni shopping cart niže, iako mislim da se moža neke stvari sad već i jeftinije pronaći:Kvad:http://www.modellhobby.de/HORIZON-Blade-Inductrix-BNF.htm?shop=k_staufenb_e&SessionId=&a=article&ProdNr=094BLH8780&t=1907&c=25625&p=25625Motori (uzeo fast i sasvim su dobri):https://micro-motor-warehouse.com/collections/tinywhoopBaterije:http://www.mylipo.de/Kamera:https://www.lindinger.at/en/helicopters/fpv-systems-und-cameras/videocameras-und-fpv-cameras/hyperion-600tvl-mini-fpv-kamera-mit-25mv-sender-5-8ghzhttp://store.flitetest.com/hyperion-mini-600-tvl-camera-w-built-in-5-8ghz-25mw-vtx/
Odg: Tiny whoop (Blade inductrix upgraded) Reply #1 – August 20, 2016, 09:35:44 pm Hvala na temi Odlicna igrackica. Skupa ali odlicna. Ja ipak cekam jeftiniju verziju npr na banggood. Vec i imaju dvije verzije slicnih quadica.
Odg: Tiny whoop (Blade inductrix upgraded) Reply #2 – August 20, 2016, 10:46:24 pm S kojom stanicom (i modulom) ga upravljaš?Djeluje jako zarazno
Odg: Tiny whoop (Blade inductrix upgraded) Reply #3 – August 20, 2016, 11:26:07 pm Imam 9XR Pro sa OrangeRX JR modulom. http://www.hobbyking.com/hobbyking/store/%5F%5F90770%5F%5FOrangeRX%5FDSMX%5FDSM2%5FCompatible%5F2%5F4Ghz%5FTransmitter%5FModule%5FV1%5F2%5FJR%5FTurnigy%5FTaranis%5Fcompatible%5F.htmlPotrebna je Spektrum DSMX 2.4GHz kompatibilna stanica (bitan note za OrangeRX modul - firmware treba biti 1.2 ili novije).
Odg: Tiny whoop (Blade inductrix upgraded) Reply #4 – August 20, 2016, 11:51:10 pm Quote from: Alpo on August 20, 2016, 11:26:07 pmImam 9XR Pro sa OrangeRX JR modulom. http://www.hobbyking.com/hobbyking/store/%5F%5F90770%5F%5FOrangeRX%5FDSMX%5FDSM2%5FCompatible%5F2%5F4Ghz%5FTransmitter%5FModule%5FV1%5F2%5FJR%5FTurnigy%5FTaranis%5Fcompatible%5F.htmlPotrebna je Spektrum DSMX 2.4GHz kompatibilna stanica (bitan note za OrangeRX modul - firmware treba biti 1.2 ili novije).Hvala na info. Super da si otvorio ovu temu, ja sam baš malo u istraživanju whoop-ja i najesen kreće "izgradnja" te se nadam da će biti još ljudi za izmjenu informacija!
Odg: Tiny whoop (Blade inductrix upgraded) Reply #5 – August 21, 2016, 01:14:45 am Nema problema. Ako budeš imao još pitanja samo piši. Kad sam slagao svojeg nisam za neke stvari nalazio ok informacija pa ću probat pomoći da se drugi ne muče sa istim stvarima sa kojima sam se i ja.Kada budem imao daljnjih razvoja na ovu temu budem ažururao originalni post.
Odg: Tiny whoop (Blade inductrix upgraded) Reply #6 – August 21, 2016, 08:51:09 pm jeftilen verzija, naravno i manje zabavna, ali moze proci ...http://www.flyfreak.net/multirotor/postaje-slike-svog-minija!!!/msg222580/#msg222580http://www.banggood.com/Eachine-H8-Mini-Headless-Mode-2_4G-4CH-6-Axis-RC-Quadcopter-RTF-p-975808.html ... 12.99http://www.banggood.com/FPV-5_8G-10mW-Wireless-Audio-Video-Transmitter-Module-TX5813-p-84761.html ... 8.09 ... treba prelemiti jumperhttp://www.banggood.com/600TVL-8_0MP-14-2_8mm-CMOS-FPV-170-Degree-Wide-Anlge-Lens-Camera-PALNTSC-p-984345.html ... 7.99 ... radi na 1S i kad quadcopter vec prestane letjetipostoji i custom firmware ali mi je to malo komplicirano za isprobavatihttps://dronegarageblog.wordpress.com/2016/01/06/eachine-h8-open-source-firmware-with-acro-mode/http://www.rcgroups.com/forums/showthread.php?t=2512604
Odg: Tiny whoop (Blade inductrix upgraded) Reply #7 – August 21, 2016, 11:23:07 pm Hrvoje imas kakav video kako malac leti, bas me zanima
Odg: Tiny whoop (Blade inductrix upgraded) Reply #8 – August 22, 2016, 12:25:17 am Izvnuo sam ga naglavacke pa su malo nastradale ove filigranske zicice od kamere, tako da ceka druzenje s lemilicom ..a moje letacke vjestine na quadovima nisu bas neke, tako da mogu samo reci da je ovako natovaren s kamerom i lc filterom solidno trom i treba mu puno gasa da poleti.
Odg: Tiny whoop (Blade inductrix upgraded) Reply #9 – September 09, 2016, 09:37:17 pm Nije tiny whoop nego neki sklepanac ali fora za letitYouTube video:
Odg: Tiny whoop (Blade inductrix upgraded) Reply #10 – September 09, 2016, 10:14:16 pm nemoj me j... da je tako dobar signal kroz vanjske zidove?!? ludilo... koji je cam/vtx/ant bundle? "Ko leti, vrijedi, ko vrijedi, leti, ko ne leti, ne vrijedi."
Odg: Tiny whoop (Blade inductrix upgraded) Reply #11 – September 09, 2016, 11:33:23 pm To je 200mw vtx, radi to super, bolje nego na mojem
Odg: Tiny whoop (Blade inductrix upgraded) Reply #12 – September 22, 2016, 11:19:08 pm Evo ima neki qx90, može se bindovat sa taranisom http://www.banggood.com/Tiny-QX90-90mm-Micro-..-Controller-FrSKY-Taranis-X9D-p-1069614.html Idući: http://www.banggood.com/Diatone-Crusader-GT2-...-p-1095494.html
Odg: Tiny whoop (Blade inductrix upgraded) Reply #13 – September 23, 2016, 08:35:20 am Quote from: xcalibre on September 22, 2016, 11:19:08 pmEvo ima neki qx90, može se bindovat sa taranisom http://www.banggood.com/Tiny-QX90-90mm-Micro-..-Controller-FrSKY-Taranis-X9D-p-1069614.htmlA ima i ovaj ...http://www.banggood.com/Eachine-X73-Micro-FPV-Racing-Quadcopter-BNF-Based-Naze32-Flight-Controller-With-Frsky-X9D-Receiver-p-1071609.html
Odg: Tiny whoop (Blade inductrix upgraded) Reply #14 – September 23, 2016, 08:47:16 am A uskoro i ovaj ... http://www.banggood.com/Eachine-Fatbee-FB90-90mm-Micro-FPV-LED-Racing-Quadcopter-BNF-Based-On-F3-Flight-Controller-p-1089814.html?p=KX28152008068201507H
