Topic: P: FRSKY X8R 8/16 CH I XJT MODUL - TELEMETRY  (Read 3946 times) previous topic - next topic
Prodajem 2 komada
FrSky X8R 8/16Ch S.Bus ACCST Telemetry Receiver W/Smart Port
i jedan
FrSky XJT 2.4Ghz Radio Transmitter Module with Telemetry
The top of the range, 16 Channel X8R receiver from FrSky with 8 normal PWM outputs and no less than 16 channels on the dedicated S.BUS output. The X8R is a surprisingly compact package compared to many 8 channel receivers and has all of the amazing functionality associated with FrSky products. The Smart Port supports the new hub-less sensors in addition to the older hub analog sensors. The X8R supports 8 standard servo outputs, with a further 8 being available by using the S.Bus line with S.Bus supported servos or use a FrSky S.Bus Decoder, giving you a total of 16 channels. Alternatively, you can use two X8R receivers in combination and the channels will sync 1-8 on the first and 9-16 on the second. The second option will give a fantastic degree of redundancy, essential when flying large models and highly desirable in any event. The X8 protocol is backward compatible, so that in D8 mode it works with the DHT, DJT, DFT and DHT-U transmitter modules. This mode you facilitate a total of 8 channels and all of the Smart Port functions so that you can still use the full range of digital sensors. The PCB antenna has been recorded as providing up to a 20% gain in range over traditional and to save weight, these antennas do not have an external case. This is an outstanding receiver for all applications and is perfect for use with the FrSky Horus, X9D and X9E Taranis transmitters, with their built-in XJT Module or any of the D8 systems to take advantage of the new digital Smart Port sensors. The firmware of the X8R receiver can be upgraded by using the USB upgrade cables available separately (please see related items.)
Features:
• 16 channels• Solid ACCST performance• Full telemetry support• Upgradeable firmware• Smart port enabled • Backwards compatible • PCB antennas• Suitable for use with FrSky digital sensors
Specs:
Voltage: 4~10.0VOperating Current: 100mA @ 5V Range: >1.5kmRSSI output: Analog voltage output (0~3.3V)Dimensions: 46.5 x 27 x 14mm Weight: 16.8g
Compatibility:All 16 channels require the FrSky Horus, X9D/X9E Taranis, or the XJT module.For 8 channels in D8 Mode you can use the FrSky Taranis or XJT, DJT, DFT, DHT and DHT-U modules
Cijena jednog prijemnika 200 kn.
Cijena modula 300 kuna.
Ako neko uzme sve komplet: cijena 600 kn.
Sve ispravno i očuvano.
095 9007 654
Odg: P: FRSKY X8R 8/16 CH I XJT MODUL - TELEMETRY
Viš nisam ni gledao, pale cijene u godinu dana od mog oglasa.
Nova cijena modula 150 kn.
Ajd uzeo bi ga onda po toj cijeni ako nije osao.
Pozdrav jel jos receiver u prodaji?
Nije. Može lock.
