Topic: Problem sa transmitterom Eachine TX5258 5.8G 72CH  (Read 3608 times) previous topic - next topic
Pozdrav
Naletio sam na problem kod samogradnje fpv racing drona..
Od opreme imam:
Okvir: HSKRC TWE210 210mm Wheelbase 4mm Arm 3K Carbon Fiber X Type FPV Racing Frame
Motori: 4X Racerstar Racing Edition 2205 BR2205 2300KV 2-4S Brushless Motor
Transmitter: Eachine TX5258 5.8G 72CH 25/200/500/800mW Switchable FPV Transmitter
Flight controller: 9g 30.5x30.5mm Omnibus F4 Flight Controller AIO OSD 5V BEC Current Sensor
ESC: 4X HAKRC BLHeli_32 Bit 35A 2-5S ESC Built-in LED Support Dshot1200 Multishot
Naocale: Eachine EV800 5 Inches 800x480 FPV Goggles 5.8G 40CH Raceband
Daljinski: FlySky FS-i6 i6 2.4G 6CH AFHDS RC Radio Transmitter
Baterije:Turnigy Nano-Tech Plus 1300mAh 4S 70C Lipo Pack W/XT60 I MultiStar Racer Series 1400mAh 3S 65C Lipo Pack For FPV Minis (Gold Spec)
Punjač: Turnigy Accucel-6 80w 10A
Sve sam to lijepo spojio, zalemio i pokusao upaliti.. cim piknem bateriju u dron cuje se normalno ono pistanje i sve to ali i iz transmittera koji je na dronu se cuje nekakvo pistanje... pokusao sam spojiti fpv naocale na kameru ali nista, izgleda kao da dobiva neki signal ali nema nikakve slike..Zna li tko mozda o cemu se radi i kako da sredim to?
