Topic: HK buddy code popusti (Read 300902 times) previous topic - next topic
Re: Fun.
Ima i na rcgroupsima thread sa kodovima
Odg: HK buddy code popusti
Vrijede do 04.06.2011.
Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack - http://www.hobbyking.com/buddy.asp?code=725650F5-A997-4203-8B95-658C8EE0B583
X-BLADE Spare SK-5 Steel blades (10pcs/set) - http://www.hobbyking.com/buddy.asp?code=034763A2-C6DF-4A84-8710-1AE7D73EB2FE
X-BLADE Precision knife with replaceable SK-5 blade - http://www.hobbyking.com/buddy.asp?code=75FB3A04-C3F8-44AE-95E4-8C98C3F6FC00
Turnigy Flat & Phillip Driver set 4 in 1 - http://www.hobbyking.com/buddy.asp?code=0F97A341-E8D8-4519-AF5D-A93C69605D71
TGY Slow Fly Prop 12*3.8SF w/ shaft adapters - http://www.hobbyking.com/buddy.asp?code=25AFDA80-C5FB-49D6-9B4A-A0ED7115E2FE
Aileron-horn Low-Profile 18x16x1mm (4pcs/set) - http://www.hobbyking.com/buddy.asp?code=ADC80CC0-B920-41CE-B519-913E3BC63619
Evo i od mene par kodova:
Turnigy AA LSD 2200mah Low Self Discharge   -   http://www.hobbyking.com/buddy.asp?code=1F2CF265-9083-4A22-913D-8A6461FC1F5D   (do 28.5)
X-BLADE Spare SK-5 Steel blades (10pcs/set)  -  http://www.hobbyking.com/buddy.asp?code=406EDFAE-4630-47C0-AFAF-7B22FE7ADBE8  (do 5.6)
HK-171 Thread Locker & Sealant Medium Streng   -   http://www.hobbyking.com/buddy.asp?code=B1D81639-05D2-4BCF-B044-1308FE107BDB  (do 5.6)
Moarti, ajde stavi u svoj prvi post veliko boldano link na onu listu svih kodova :)
evo buddy kodova
Flat 26AWG servo wire 1mtr (R/B/W) - http://www.hobbyking.com/buddy.asp?code=A1EF570A-7533-4F16-B83A-5DAE24C32BB2
Polyester Velcro Peel-n-stick adhesive side  - http://www.hobbyking.com/buddy.asp?code=B3895D1E-4406-41E9-8F1B-B3312323DCC9
   9x5 Propellers (Standard and Counter Rotatin - http://www.hobbyking.com/buddy.asp?code=BA16FBDD-AD86-4FDD-8610-7F83E80E77A9
   7x3.5 Propellers (Standard and Counter Rotat - http://www.hobbyking.com/buddy.asp?code=0E135F71-9CC5-44F0-B25C-555C7AC1DCFC
   TURNIGY Plush 60amp Speed Controller (odličan esc) - http://www.hobbyking.com/buddy.asp?code=8E03A3CE-B406-43F4-BB3F-5AADAF9391BD
   HK-171 Thread Locker & Sealant Medium Strength - http://www.hobbyking.com/buddy.asp?code=42DAAE20-5755-4994-B602-0C5A022A8D06
to je to za sada, žao mi je kaj nisam prije to sve stavljao
flyfly mirage 2000
dva mala...
Code: [Select]
[URL=http://www.hobbyking.com/buddy.asp?code=FF65D93A-47C0-4A0F-B10E-D5ED5E828F9C]Maxi-Cure Extra Thick CA 1. oz[/URL]                                   Save US$: 0.32
[URL=http://www.hobbyking.com/buddy.asp?code=1D11477E-5612-458A-B021-3922524348F8]Maxi-Cure Extra Thick CA 1. oz[/URL]                                   Save US$: 0.32
Oho, vidim sprema se zesci setup za me163
