Topic: HK buddy code popusti (Read 304306 times) previous topic - next topic
Odg: HK buddy code popusti
Reply #315
Odg: HK buddy code popusti - baterija, kontroler, stekeri
Reply #316
TR_P12A-E    TURNIGY Plush 12amp (2A BEC) BESC
http://www.hobbyking.com/buddy.asp?code=2DA45902-FBD5-4FDF-A153-989AFE4EBA98
T1000.2S.20    Turnigy 1000mAh 2S 20C Lipo Pack
http://www.hobbyking.com/buddy.asp?code=3DC071BE-1EDB-4637-B817-F9EE9D8C0D6F
AM-1024Bx10    JST Female 2 pin connector set (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=8B24E310-F8C7-4FB4-BA90-F6324E23637E
AM-1024Ax10    JST Male 2 pin connector set (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=62141BB6-DCF4-499E-8A2F-6F440B431745
OR012-00702    Nylon Snap-Click style clevis 10pc
http://www.hobbyking.com/buddy.asp?code=D1B4C5DF-29C8-4D5A-94CC-E7BEFEEC46DA
Reply #318
Reply #320
Reply #321
VRIJEDI DO 17.07.2012.
http://www.hobbyking.com/buddy.asp?code=B2A307BF-AEA0-4A47-84B7-A11955ACEAF5      Turnigy AE-30A Brushless ESC
http://www.hobbyking.com/buddy.asp?code=0ED7AF1F-6783-4E5C-9770-DF45B9D4FDC6             Turnigy nano-tech 2200mah 3S 35~70C Lipo Pac
http://www.hobbyking.com/buddy.asp?code=C98922AF-5583-4500-8F88-4B23A6DD4E97           S2838-2800 Brushless Inrunner (2800kv)
http://www.hobbyking.com/buddy.asp?code=D8FE269F-4D20-4871-A50C-1294B9283EBA           4mm Gold Connectors 10 pairs (20pc)
http://www.hobbyking.com/buddy.asp?code=5B8D8EBC-7BA5-49D6-B8EA-E523EA1B1883           Twisted 80CM Servo Lead Extention (Futaba) 2
http://www.hobbyking.com/buddy.asp?code=BE5716A2-AB7D-45FC-A616-7C21D8DB0168          Prop adapter w/ Steel Nut 3mm shaft (Grub Sc
http://www.hobbyking.com/buddy.asp?code=9C2234CB-9321-46F5-B589-828083477929           Linkage Stopper M3x2xL11.2mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=F63C9163-E515-42BE-8931-D0D501137B3A            Metal Push Rods M2xL300 (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=56BC71A8-45CB-40BF-81E7-58784079CF95           JM 6x4 /152.5x102mm propeller (2pc/bag)
Reply #324
Reply #326
Reply #328
