Topic: HK-450GT Pro 3D Belt-Drive (Read 17635 times) previous topic - next topic
Poštovani "kolege" Helimajstori...
Kao prvo lijep pozdrav iz Rijeke...
Kao drugo, kupio sam u Konzumu 2 helića koji su ubrzo stali (loša kvaliteta i nema rez.djelova)  ;D
pa sam se odlučio da se okušam na nečemu boljemu....
Izbor je pao a nadam se da je ovih 10 dana surfanja po forumima urodilo plodom....
Ovo je moja lista naručenih "nečega" i "svačega"  :D
Molio bi Helimajstore da mi savjetuju što uzeti za rezervu i što bi bilo dobro zamjeniti sa nekim djelovima iz drugih marki (Tarot, Align) pošto nailazim na svašta....
HVALA, HVALA,,,,,,,
HELIKOPTER
HK-450GT Pro 3D Belt-Drive Helicopter Kit (A
HXT900 9g / 1.6kg / .12sec Micro Servo  5kom
HobbyKing HK-922MG Digital Metal Gear Servo
Hobby King 401B AVCS Digital Head Lock Gyro
Turnigy Typhoon 450H 2215H Heli Motor 3550k
GT450PRO Drive Gear Set 11T/13T 3.15mm
TURNIGY Plush 40amp Speed Controller
Turnigy nano-tech 2200mah 3S 25~50C Lipo Pac
PUNJAČ
Turnigy Accucel-6 50W 6A Balancer/Charger w/
DODACI
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC
Nylon XT60 Connectors Male/Female (5 pairs)
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
Turnigy 4mm Heat Shrink Tube - RED (1
Turnigy 4mm Heat Shrink Tube Yellow (1mtr)
Rubber Grommet for servos (10pcs/set)
REZERVA
HXT900 Replacement Gear Set
TIG 62mm Carbon Fiber Tail Blade
325mm Carbon/Glass Fibre Composite Main Blad
GT450PRO Feathering Shaft (51x4mm) 2pcs
GT450PRO Stabilizer Bar
ALAT i LJEPILO
R/C Helicopter Pitch Gauge
HK-171 Thread Locker & Sealant Medium Streng
HK-173 Thread Locker & Sealant Permanent (Re
HK-175 Thread Locker & Sealant High Strength
STANICA i BATERIJA
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) – Naručeno na rcmonstershop.com
ZIPPY Flightmax 2500mAh Transmitter Pack (Fu
LP .......  8)
Odg: HK-450GT Pro 3D Belt-Drive
Ma za sada leti ovako.
Trebao si uzeti ona Assan ga-250 zirac
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15318
Ovaj 401B kad ga dobijes moras modati, zaljepiti plocicu sa silikonom za kuciste.
Nadji na netu 401B fix :)
dobro si ti to zamislio, svaka čast.
kao što je wespen rekao zasada dok ti skilovi ne napreduju leti sa tim setupom.
evo linka kako treba napraviti fix na hk401b žiroskopu. sretno =)
HK401 Gyro Fix.
InnovationMatters
Zahvaljujem Wespen-u i Dado-tu na odgovorima..
Nadam se da će sastavljanje biti uspješno, paketići su na putu  ;D
I obavezno ću odraditi fix...
Veoma sam zadovoljan da sam složio nešto kopajući po forumima i da nemate većih zamjerki.
Na HK dobili su i "GT450PRO Main Shaft"  pa ću i to naručiti...
Molio bi za informaciju što još rezervno naručiti ? , što se najviše lomi...
Da li je bolje uzeti carbon/fiberglas ili fiberglass Main Blade ? ili drvene možda?  ili čista plastika?
Treba li mi još nešto za sastavljanje,  da  poslije ne ludim,... ::)
Naravno imati ću još pitanja i molim da mi ne zamjerite...
HVALA   :D
od alata vidim da nemaš kliješta za ball linkiđe, hex iliti imbus 2x 1.5 , 2.0
što se tiče rezervnih djelova kao početniku ti preporučam drvene blejdove( bolje nek pucaju oni nego glava) , a nikad dosta i repnih , šaftova (vertikalnih fs, okomitih ms, repnih) , rezervni headset...
Imam gotovo isti setup osim žira(401 Futaba) i repnog serva DS480.
Corona 929MG Metal Gear Servo 2.2kg/ 12.5g/ 0.10sec su mi na kolektivu.
Uzmi koji remen. Meni je naime prvi se totalno otpustio. Pa sam uzeo dva s HK i drugi ide prema tome isto.
Pa sam na netu našao neke žute kevlar reinforced belts, i stvar je super.
Mislim da bi ti bila zgodna Turnigy programing card da se ne zaj**** s namještanjem. S njom je stvar totalno jednostavna, tipa soft start da namjestiš itd. A nije neka lova.
GT450PRO Stabilizer Bar uzmi par komada odmah.
> a ostalo sve si izabrao totalno pro!!
Ako ga nećeš rušiti , brijem da ti većina od toga neće ni trebati odmah.
A ako ga srušić, mislim da je ipak glava stvar koja će prvo otići. Ja sam uzeo dva helija odmah ispadne jeftinije a imaš sve djelove rezervne:)
PS:ako ideš s koaksijalnog na 450PRO napravi obavezno neki training gear set ili nešto. Da ne bi bilo loma.
osovine repnog rotora s remenicom, i nekoliko elisa
meni je jedna otisla na Domovinskom jer je glavni rotor podbacio kamencic,
druga je otisla jucer na terasi, kako ne znam jer nigdje nisam opizdio,
trecu nemam,
dakle ako netko ima koju viska za prodat dok ne narucim iz HK, ima kupca,
ako ne morat cu montirat tork tube dok ne stigne,
P.S.helic jos nije bio u zraku vise od 20 cm visine  :'(
Mislim da ja imam jednu, moram pogledati kad dođem doma pa ti javim.
Drugi put ga digni na par metara pa ako padne barem je bio na par metara :P
A možda i je problem kaj nisi ga dignuo na 1-2m pa da imaš vremena korigirati ako nešto pođe po zlu.
Ja kad idem s trave ili nečeg nosim kartonsku kutiju pa stavim ispod, pa ujedno i vježbam sletanje na nju :-\
PS:na 6ch heliću još nije bilo nose-in letenja :-[
ajd vidi, ako imas osovinu imas kupca
ma komplicirana prica, imam Belta i onda mi rekose kupi nekaj posteno i tako uzmem od Ddarka stanicu i od Neoa helic, Waspen naruci dijelove, slazem to uz Waspena i Simpija i na kraju odem na Domovinski i treba dici helic da se potrima u zraku i eto sranja jer nisam produzio repnu peraju,
onda sam duze vrijeme bio u guzvi i slozim tu repnu, sredimo ostale stvari, i doma idem malo zavrtit rotor sve 5 stanem i vidim da se boom tail zakrenuo, hvala Bogu nigdje nisam lupio, jucer to sve pricvrstim i polijepim idem ga zavrtit a osovina u banani,
kako gdje i kad, nemam pojma.
bad luck, ali barem perem simulator :(
Uzmi si barem 3 para drvenih elisa koštaju nekih 2 i pol dolara, jer u startu češ najvjerojatnije barem par puta slomiti glavne elise a ove su solidne kvalitete za pocetak. evo linka:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14011
uzmi si barem 4 glavne osovine i 4 feathering shafta,
rezervni swashplate,
2-3 seta flybara(šipka i papučice)
4 seta plastičnih repnih elisa(50 centi kom),
barem jedan tail unit housing ,
tail control ručicu i tail blade grips
barem 2-3 tail boom cjevi,
2x osovine za repni rotor
vertikalni i horizontalni finovi( tail fins)
1 par skija i set ručica(rotor linkage set)za kontrolne ruke na rotor setu
znam da se čini puno toga ali i nije neka velika cijena za sve to zajedno ali sa ovim paketom koji sam ti preporučio imat češ puno manje frustrirajuči start jer čekanje ovih osnovnih dijelova koji su prvi na udaru je noćna mora, osim toga ovi dijelovi bi mogli potrajat i 3 mjeseca ovisno koliko letiš na tjedan.
JAKO BITAN savjet kao što ti je već i spomenuto jest da ako ne kupiš barem da si napraviš training gear od dvije daščice ili čega već, neka dužina training gear-a odgovara promjeru rotora. na vrhove možeš staviti stiropor i malo ga omotati izolir trakom tako da klizi po tlu a ne da zapne.
Jedan tip: napravio si fantastičan odabir helikoptera iz jednostavnog razloga, šasija je robusna(čvrsta) i super jednostavna za instaliranje elektronike i servoa, jedino što moraš razumijeti jest da 450pro verzija je malo više aksilnija od ostalih, više za 3d manevre negoli su to prethodne verzije, to nije ništa strašno, ako budeš osječao da je helikopter previše osjetljiv bez obzira na podešavanja na stanici slobodno možeš uzeti rotor headset od V2 verzije i ugraditi to na svoj 450 pro, jedino što mora biti od 450pro u tom  headsetu jest glavna osovina i swash plate. =)
Lijep Pozdrav =)
InnovationMatters
Kad ste sutra na Luckom? Imam neki obavezan rucak a volio bi navvratit, ak nis drugo da barem krug sa Zlynom napravim (450 ceka osovinu a za Belta imam samo jednu bateriju
Ljudi ....hm.... HELIMAJSTORI.. ;D
Svaka čast na odgovorima, složiti ću si sutra jednu narudžbu rez.djelova....
Već su mi 2 paketića od 6 u Rijeci, jedan je prošao carinu bez beda a drugi čeka....
Naručio sam 5 pari drvenih elisa po dobroj cijeni i poštarina free, pošto na HK-u nemaju
ako koga zanima evo link
http://www.goodluckbuy.com/5pairs-325mm-wooden-main-rotor-blade-for-align-trex-450.html
Ne znam da li valjaju...ali....
ps.
Dado, stvarno hvala na iscrpnom odgovoru.  :D
jel se moze HK450 sa CP prebaciti na FP ?
Ne...kakva su to sad pitanja?
Jel mogu ja od motora napraviti auto? Ono samo jos 2 kotaca stavim :)
mozes, KTM je to napravil jako uspjesno,
a i Yamaha se necim dici,
MP3 skuter je totalni mrak (doduse 3 kotaca) al ej pila tak dobra da za njeg delaju i zimske gume, u kombinaciji s ABS-om i elektrodekicom gotovo da si rijesio cjelogodisnji problem s parkingom u ZG.
Pitanje je postavljeno jer navodno:
a) FP su laksi za letit
b) laksi su za slozit i postelat
c) jeftinij su za slozit i postelat.
Dakle pretpostavljen situacija glesi da si covjek nabavi nekaj, pocne sa FP, to onako izvjezba pa predje na CP, a bazu ima znaci promijeni neke dijelove i eto ozbiljne pile.
nesto kao bicikl s pomocnim kotacima, kad naucis skines pomocne a ne moras kupovat novi bicikl.
