Topic: Protos 700 (Read 36267 times) previous topic - next topic
Protos 700
Stvari se pomalo otkrivaju:
 HF: '' We are currently flying/testing the Protos 700, it runs on a single belt design like all our other helis. So far transmission system didn't show any particular issue.
 Hopefully we will have some videos up in a month or so.
 Corrado"
HF: "
... some quite old infos, directly from Corrado, from italian foru.
 "Probably, starting from May, Protos and MiniProtos will be sold "exclusively"  FBL and, oviously, there will be a combo with "Brain" the MSH FBL System "
 "The Maxi-Protos I think will be presented at Nuremberg but it will be marketed very + forward, towards year-end would say, soon begin to appear the first videos ...."
 The maxi protos:
 Blades: 700 mm;
 Lipo: 12S;
 Mono-belt trasmission;
 Stock,  MSH rebranded, Scorpion motor + YGE."
http://www.helifreak.com/showthread.php?t=368349&page=4
Meni je zanimljiv kao 600tka. MSH FBL, vjerojatno rebrandirani neki od vec poznatih?
Outrage Fusion 50
Futaba T14SG
Odg: Protos 700
A talijanac tvdi da FBL kontroler razvijaju in-house.
Bumo vidli uskoro. Toy Fair je vrlo blizu
Odg: Protos 700
Evo i prvi video
Dario Neuenschwander test the new Protos 700 with Brain flybarless system
Motor: Scorpion 4535
 ESC: Jive 120
 FBL System: MSH Brain
 Tail servo: Outrage BL9188
 Ciclic servos: JR8717HV
 Batteries: Giga Power 5200 12S
 Rx: Futaba 6203 Sbus linked to Brain trough sbus channel
 Everything running direct on 2S Lipo
 SAB Blades 710mm
Odg: Protos 700
taman dok se ja naučim letit sa 500 , bude izašla 700 tka  ;) ;) ;)
dx9-xd8-gobac630
Odg: Protos 700
evo sam se taman vratia sa AHS i moram reci da protos 700 moram imati.... ostavio je na mene takav dojam da nije za vjerovati.... zvuk prejeben, i performanse pre predobre kako ga je lik samo prao pa to nisu istine... po meni protos je zauzeo prvo mjesto prejaka pila
[move]Fly With Your Fucking Soul
-T-rex 600e, Raptor 30 v2, Outrage Velocity 50,
-Hitec aurora 9[/move]
Odg: Protos 700
Nekak djeluje praznjikavo ... Pa ta repna getriba ... Donji frejm je izgleda plasticni ... Ljubicasta boja ...  :-[
Outrage Fusion 50
Futaba T14SG
Odg: Protos 700
Bas sam im na HelifReaku napisao.
http://www.helifreak.com/showpost.php?p=4328697&postcount=7
opet lagani frejm, MSH filozofija.
Pak nebu nista od helica ostalo kad padne.
A za rep, pretpostavljam da zbog nedostatka drugog zupcanika za pogon repa moraju imati ovakav kotac na kraju da dobiju okretaje koje moraju.
Odg: Protos 700
hahhahaha :D
Odg: Protos 700
3 ipo minute ciste pornjave  :D
skype: niram_zd
Odg: Protos 700
da... hard core
Odg: Protos 700
Djeluje pomalo artisticki! Repni blok mi izgleda neuvjerljivo ???, dok drugi rade monoblokove ovdje su nekakve slabasne djindje-mindje >:(! No kazu da je proto(s)tip ;D...A je nekak filigranski odradjen.
3 x rc helikopter :P
