Topic: Turnigy 9x nasljednik 9X-R (Read 64767 times) previous topic - next topic
Odg: Turnigy 9x nasljednik 9X-R
Kak sve izgleda, ovaj petak bi trebao biti "taj" dan!!  8) 8)
lp,
Marko
a na prvi pogled izgleda cool, koliko vidim rade sa FrSky za nadogradnju modula, ocito sa telemetrijom na displayu, antena integrirana u rucku... fora
Ipak...
 Release Date: Between Dec 20 and 25!
Jezuš, djeluje mi ko neka igračka, pomalo neozbiljno :(
Istina kada covjek vidi te ruzne plasticne prekidace  pomisli sto je tek unutra , no s druge strane i sa starom leti na tisuce ljudi pa je dobra a nova bi trebala biti jos bolja po nekoj logici, treba vidjeti, ja osobno ne dajem ni dolara dok stara futaba radi  ;)
Oćemo prvi?
Ili da čekamo prve kritike.
Outrage Fusion 50
Futaba T14SG
Evo ga!
http://www.hobbyking.com/hobbyking/store/__31544__Turnigy_9XR_Transmitter_Mode_2_No_Module_.html
9XR Standard Features:
• 8 Channel PPM/9 Channel PCM
• Full Ball Bearing gimbals
• Adjustable Stick Length
• Digital Trims on all Primary Axis
• 16 Model Memory
• Assignable Switches
• Freely Assignable Channel Mixes
• Graphical Dual Rate and Exponential
• Sub Trim and Travel Adjust
• Flaps and Differential
• Throttle Hold
• Supports Heli/ Aero/ Glider Model Types
• Programming Templates Based on Model Type
• Supports M1, M2, M3, M4 stick modes
• 128 x 64 backlit Liquid Crystal Display
• Built in JR & Futaba Trainer Ports
• PPM & PCM Output
• Utilization of JR Form Factor RF Modules
• Programmable Timers
• Low Voltage Warning and Buzzer
• Supports 3s Lipo (Required)
• 9XR Firmware Pre-loaded
• AVR ISP Interface
• Internal 2.4GHz Antenna
lp,
Marko
Valjda ce danas biti i baterija. Kutija je tu al me ona ne zanima.
Outrage Fusion 50
Futaba T14SG
Ne da kombinirati narudjbu tako da ionako moras naruciti odvojeno, slobodno probaj dodati u kosaricu jos nesto.
Attention
Sorry, the below product(s) are large items and can only bought 1 at a time and cannot combine with other items. Please separate the order:
Turnigy 9XR Aluminum Carrying Case
Turnigy 9XR Transmitter Mode 2 (No Module)
A nude kao combo price!?
Sad mi je krivo što sam kupio 9x a nisam pričekao 6mj...
Ko leti vrijedi,
ko vrijedi leti,
ko ne leti ne vrijedi!
Za 9x uvijek imas kupca, na ovo ide modul od oko 50$ tako da je skoro duplo skuplja.
Ne skodi imati i koji stanicu rezerve, recimo 9Xr za LRS a 9x za parkflyera...
P:Turnigy 9X
K:Turnigy 9XR
Bit ce i drugih mozda boljih kineza, npr. FrSky bi isto mogao uskoro nesto izbaciti.
BTW Orange modul je 29$ a postarina 3$.
Outrage Fusion 50
Futaba T14SG
Za orange modul treba kupiti i prijemnik ( nije uz modul) i ako se zeli 7 ili vise kanala sa failsafe to je dodatnih 18-22$, iako ima i 5.89$ s 6 ch bez failsafa.
