Topic: Mabuchi RS-380PH / Brushles motor rač. okretaja (Read 1446 times) previous topic - next topic
Ovako zanima me pošto sam uspio naći podatke za navedeni motor i u specifikacijama mu piše da se vrti na prazno 2.000 okretaja u minuti.
Kako se računa to isto samo na brushles motorima?
I dobivao sam info da motor ne radi na večoj struji od 9.6v a u spec piše od 5V-12V - dali ima itko iskustva???
Evo recimo Brushles motor 1400Kw na 11.1v.
Mabuchi RS-380PH Hobby Motor - 7.2V DC - 2000 RPM - Great for R/C Boat Applications
Brand new motor manufactured by Mabuchi
Model RS-380PH
Operates on 7.2 V DC
Will operate from 5 V DC to 12 V DC
No load speed is 2,000 RPM
No load current is 30 mA
Stall current: 480 mA
Can be operated in either direction, simply reverse power supply polarity
Dimensions (not including shaft): 37.8 mm long x 27.7 mm diameter
Shaft dimensions: 13.8 mm long x 2.3 mm diameter
Comes with 2 solder eyelets for easy connection
Features 2 threaded mounting holes on 16 mm centers (JIS M2.6x0.45)
