Topic: FYI : Naručivanje baterija iz HK samo do 3200mAh (Read 4521 times) previous topic - next topic
FYI
Evo danas sam htio naručiti baterije 2x5000 3S i jednu 1500 3S kad ono ograničenje za kapacitet na 3200mAh.
Opcija slanja je preko EMS sa shipingom od 78$ umjesto 24$ koliko bi ispalo standardnim
slanjem  :( .
Ta informacija se dobije klikom na
Total Li-Po capacity: 11500mAh
[/t][/t][/t]
Shipping Li-Poly batteries by Air Parcel
Due to international air safety regulations, parcels with a total battery capacity of more than 3200mAh cannot be sent via standard 'Air Parcel'.
Please select Air Mail, EMS Express, UPS, DPD, SingPost Air Parcel or DHL where available.
If you insist on using standard Air Parcel, then either reduce the lipo capacity ordered per parcel, or order from one of HobbyKings US, EU or AU warehouses without limitation.
Options.
1) Order via EMS Express, UPS, DPD, Air Mail, SingPost Air Parcel or DHL if available.
2) Reduce total battery capacity to under 3200mAh.
3) Order from Hobbyking.com DE, US or AU warehouse if available.
Your Total $83.55
Standard Price $224.89
[/t][/t][/t][/t][/t][/t]
Postage & Payment type
Shipping Options
CROATIA  1101g
EMS Express to Croatia (MAX 1.5kg)  $77.69
 International (Registered) Air Mail 1.5kg  $23.59
[/t][/t][/t]
Discount code:
Hmmm, kako onda naručiti jednu od 5000? Tražiti da ju prepolove i pošalju u 2 paketa?
Odg: Naručivanje baterija iz HK FYI
hmmmm
a ja se baš napikiro na jednu 3s 5000 jer sam subotu oštetil jednu jedniu koju sam imal tak veliku....
majku mu.....
a ja bum uzel kaj se uzet da.... pa bum spjajal ...
inako sam složio tih adaptera svih vrsta....
u skupoj poštarini nije samo problem njene cijene nego i toga što to onda ovi na šprediciji ocarine i naplate čudesa....
Odg: FYI : Naručivanje baterija iz HK samo do 3200mAh
khm, sad moram ponistavat narudbu  :D
stavio 3s 5000mah 35-70c batku u kosaru, napravio checkout sa shippingom 14,99$ i to je to. nikakva ogranicenja?
btw meni nudi samo ems ako je paket preko 2kg. kolko ti je tezina paketa?
Ne radi se o težini paketa nego o kapacitetu baterija
( težina paketa je poznata stvar )
ok, al sad 2 puta napravio narudbu preko 5000mah baterija i nije nis drukcije nego prije. a desilo mi je jednom da sam uzeo par baterija i ostalih gluposti sto je ispalo 1970gr i kao opcija shippinga mi je bio samo ems sa svojim povoljnim shippingom  :P
probao i ja isto sada, normalno mogu naručiti 2x3700 6s klasični airmail.
Naručujem
Razlika ja između Air Mail i Air pacel tako da prolazi
Jedno je vjerovatno hk post (preko kojeg nemremo uzimat lipo baterije) a drugo je swiss post di prolazi
Vjerojatno
Malo me zbunilo kako nudi pod opciju slanja a klikom na kapacitet ograničava .
Lažna uzbuna i igra rijeći ( mail - parcel )
Stara priča, uvijek ima način.
Da Kina zabrani, HK bi izmislio letove ili vagone za izvoz ;) ;) ;)
Ma tko još treba Zippy i Rhino kad imamo Gens Ace :)
Treba podržat lokalne dilere i dobavljače (i one susjedne)
Istina no meni dobro zvuče ovi koji nude najviše za najamanje love.
Tako i tako domena mi je trenutno batke do 3000mah pa nije problem.
Domaću nabavu kad spuste cijene možda.
