Topic: Blade 550X (Read 1694 times) previous topic - next topic
Blade 550X
Evo i tvornica igracaka je odlucila raditi ozbiljnije helice :)
eFlite Blade 550X Pro blah blah nesto nesto
http://www.youtube.com/watch?v=RF105E34ZvY
550 X Pro Series Kit: $639.99
550 X Pro Series Combo: $999.99
Kazu ovako:
Welcome to the world of Blade® pro-class helicopter performance. Over two decades of flying and design experience have gone into the development of the Blade 550 X. Every part, down to the nuts and bolts, has been chosen or designed with one goal in mind–giving you a no-compromise, 550-size 3D machine that is second to none. Both kit and combo versions of the Blade 550 X arrive ready for you to assemble with motor, speed control and BEC. The Blade 550 X Combo also includes a Spektrum™ AR7200BX Flybarless Control System, 3 Spektrum H6040 digital metal geared servos and an H6080G tail servo. The 550 X is a no compromise thrill machine that delivers the performance expert helicopter pilots demand.
  • Direct-to-swash, flybarless head design
  • Carbon fiber main frames
  • CNC machined aluminum head block
  • CNC machined aluminum swashplate
  • Revolution™ 550mm carbon fiber main blades
  • Triple ball bearing supported, 10mm solid steel main shaft
  • Integrated bearing block servo mount design
  • Torque-tube driven tail with aluminum tail boom and case
  • Dual point tail pitch slider and balanced tail grips
  • E-flite® 130A ESC
  • E-flite Heli 550, 1360Kv brushless outrunner motor
  • E-flite 10-Amp BEC
ajde, barem su sablje postene :)
