Topic: preporuka za kameru (Read 6628 times) previous topic - next topic
preporuka za kameru
Preporuka za kameru a da nije go pro
Potraga za kamerom za snimanje sa hekse
Odg: preporuka za kameru
Pogledaj explorer hd camera na you tubu ja mislim da je treći video Alishanmao govori o njoj
Ima li ju netko na forumu?
Ja imam ovu
Teška je 95g, ima nosač za šoferšajbu, više vrsta modova, display
Teh podaci:
1. 120 degree ultra wide angle lens.
2. 1920x1080P FULL HD high quality resolution.
3. Advanced H.264 video compression technology.
4. 16 mega pixels.
5. Video record / photograph angle, can be adjusted to 70 to 120 degree ultra wide angle.
6. 4X digital zoom, ranges from 12cm to limitless distance.
7. 2 inch high resolution LCD, can watching while shooting.
8. Matching LED for supplementing light at night.
9. Support HDMI high quality video transmission.
10. 3 resolution forms can be changed for video recording.
11. 180 degree adjustable for the lens from upside to downside.
12. 30/60 frames per second for smooth video flow.
13. Equipped with special auto suction cup holder. Conveniently fix and use.
14. Seamless continuous recording, will not miss any data.
15. Powerful document protection, even in the recording process, the occurrence of sudden power outages, machine damage, etc., video files will be intact.
16. Adopt auto cigarette lighter power supply, to make the video recording while driving.
17. To start the auto automatic off; to start the video recording function.
18. Automatic circulating video recording, being able to set the record time for each file.
19. Watch video while make video recording in driving. Support on-spot play back.
20. Improve time & date display, need no reset when re-start.
21. Set the video recording time, stop recording when the setting time is up.
22. Screenshots function, can capture the video screen while video recording and reviewing.
23. To charge through USB.
24. Bottom stand adapt the foot of the camera, convenient for photographing and video recording.
25. Human orientated operation interface.
26. Maximum 32GB or even bigger TF high capacity storage device.
27. High capacity BL-5C mobile lithium cell.
Link: http://www.carcameradvr.com/h8000-car-camera-full-hd-1920x1080p-sports-hd-video-camera-p-53.html
Video koji je sniman s njom ( kompresirano i smanjena reza)
CNC rezanje zagija
F8000 Car DVR - FPV Test /Sunrise/
 Odlično čak !  ;)
Nema velikog plivanja slike.
A težina je vjerojatno manja od GoPRo i nema "riblje oko" izraženo.
A sada i avione! :-(
Ok
Da cujem jel se jos nesto nudi osim ove dvije
Ne za FPV vec za snimanje videa i recimo da sam spreman platiti kvalitetu
ako si spreman platit kvalitetu
NEcuuuuu go pro
Hocu pravu kameru
Sony RX1
Sony NEX 7 6 5
Imaš u AVmax u Zagrebu SONY NEX 5 za 4100 kn.
Ima samo 16mm širokokutni objektiv koji nema riblje oko.
Sve zajedno 350 g. Snima full HD a odlične fotke radi ako kupiš IR samookidač vremenski.
Isti takav ja imam na mom SONY NEX 5N.
