Topic: SAB Goblin 500 - objavljen datum izlaska i cijena (Read 2115 times) previous topic - next topic
Evo danas iz SAB-a
We are happy to announce that the highly anticipated Goblin 500 will be available for sale on February 12, 2013. The price will be $649 / 594 Euro including main and tail blades.
Evo ga za manje od mjesec dana, sa popularnim cijenama  :D
Skoro 600 Eura za goli helic.
Detalji:
Main rotor diameter:  1136mm (with 500 mm blades)
HPS Head (FBL Only)
Main blade length: 470 to 500mm
Tail rotor diameter: 226 mm
Tail blade length: 80 mm
Main shaft diameter: 10 mm
Tail shaft diameter: 5 mm
Spindle shaft diameter: 8 mm
Gear Ratios 6.9-11 : 1
Weight including electronics: 1900 g (excluding flight battery).
Special Features:
Full carbon fiber boom
Quick release battery tray system
Sacrificial breaking point for landing gear and boom
Unique “inside the boom” tail push rod design
Evo setupa:
• Cyclic Servos: Mini size (36mm)
             Normal and 3D Flight: Hitec 5245 MG, Align DS510M or DS515M, Savox SH1250, Graupner DES 678 MG, MKS DS-9660A, Futaba 9650
              HARD 3D: Futaba BLS153, Graupner HBS660 HV, JR DS3717 HV, HITEC 7245 MG HV, JR DS3711 HV
• Tail Servo: Standard size (40mm)
• Typical Speed Controller: 80/100A
              Normal and 3D Flight: Kontronik Koby 90, YGE 100 LV
              NARD 3D: Kontronik Jive 100 LV, YGE 120 LV, CC Talon 90
• Motors: (Max Diameter: 52 mm, Max Height: 52 mm)
              Normal and 3D Flight: Scorpion HK-4015-1070, Quantum 4115-1200
              HARD 3D: PYRO 600-1200, Scorpion, HKIII-4020-1100/1350
• Flight Battery: (Max Dimensions: 52x53x180mm)
              6S 2800/4500 mAh.
Netko je izracunao da ce ispasti 600 Eur skuplje od full nabrijanog Trex-a 550
Ne vidim im bas racunicu....
Ali da guba izgleda...izgleda :)
Odg: SAB Goblin 500 - objavljen datum izlaska i cijena
Kaze frajer na fejsu
"I hope the the ppl @ SAB include a jar of Vaseline in the kit"   :D :D :D :D
koliko sam skužil po helifreak.u ovi iz sab.a nadknađuju djelove ekipi koja dokaže da nekaj nije bilo u redu...
to kod aligna baš nisam videl , valjda je i to dio fore sa cijenom ,
uostalom stvar dizajna , a tu nema ravnih ragacama.... ;)
dx9-xd8-gobac630
Bert je sa 700-tkom zadrapao po podu sa repom da se sve dimilo... Nastavio let, odradio do kraja i sletio sve 5. Tak da košta ali valjda i vrijedi. Vidio sam da je ekipa vraćala kitove zbog sitnica (doslovno tipa negdje ispod mu je canopy 1mm dalje od nekud drugdje) i dobivala nove.
ovo je klasa za sebe!!!! ;)
realno po meni ni 500 ni 550, nekaj između... ::)
jedino cijena.... fakat paprena, ali opet jebaj ga, po svemu je najbolji :P :P :P Što jest, jest!!!!
saka čast feragostičari!!!  ;D
