Evo i malo testiranja jeftinih (15$) zamjenskih prijemnika
Na ZagiXL je isto jedan takav.
Range test s low power prodje
Bind je super jednostavan ne treba zicica samo se izabere bind i stanica kaze successful.
Telemetrija rx voltaze radi.
Failsafe radi.
Model match radi. ( reagira samo ako je model s kojim je bindana)
DM4F 4 channel DMSS Parkfly Receiver
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=24705&aff=448825MICROLITE DMSS Receiver
DMSS 4CH 2.4G Receiver
Features:
-Work with JR DMSS radio XG6,XG7,XG8,XG11
-4 channel parkflyer receiver
-DMSS modulation system
-2.4G coaxial antenna
Application:
Special for small electric and non-power airplanes and Electrical Helicopters.
Caution: Not for use in Nitro and Large electric airplanes and helicopters.
Specification:
Type: 4 CH Parkflyer
Modulation: DMSS
Dimension(WxLxH): 16.5x35x9.2mm
Weight:3.5g
Input Voltage Range:3.6-10.0V
Binding
The DMSS Compatible receiver must be bind with the transmitter before it will operate.
1. Connect the battery( or BEC/ ESC with BEC output) to Batt.channel and note the LED on the
receiver should flashing, now, the receiver is on bind mode.
2. Power on the transmitter, and enter the BIND menu.(Checking manual of your transmitter,
how to enter the BIND menu. )
3. Press the BIN button on the display. The system will connect within a few seconds. Once
connected, the LED on the receiver will go solid, indicating the system is connected.
4. Exiting from the BIND menu, and then setting the failsafe according the function of your tansmitter.(
Please check failsafe function of your transmitter)
Caution:
-DO NOT stick or apply the receiver antenna to Carbon or Metal material directly, as it will
drastically reduce the operating range.
-For receivers with multi-antennas, it is recommended that each antenna be applied at 90degrees to each other.
-For receivers with single antenna, please apply the antenna far away from any carbon, metal
or electronic equipment as possible. Advanced Duplex
Modulation System
Note:
-Make sure turning the transmitter first after binding when using your radio control system.
-Make sure setting failsafe after binding.
