Odg: Re: Zagi alteration Reply #30 – January 25, 2013, 09:17:10 pm Quote from: mbalunovic on January 25, 2013, 08:55:53 pmKoja vam se vise svidja za edf? Milos @ Galaxy S3Meni bi se najvise svidjel ta koju uradis i uspijesno poletis,"Papir" sve podnosi !
Odg: Zagi alteration Reply #31 – January 25, 2013, 09:27:54 pm Jarun, upravo ga radim, Plavi, zasto je to problematicno za setup ?sve moze da stane u njega. profil je debeo 40mm na najdebloj tocci, uzmu se tanje baterije, esc moze napred, neznam, al mislim da se lako moze rasporediti, da bude teziste tamo di treba,
Odg: Zagi alteration Reply #33 – January 25, 2013, 09:49:49 pm Quote from: srepfler on January 25, 2013, 09:47:36 pmOvaj EDF bi bio interesantan Koliko se moze vidjeti izgleda veoma dobro,molim te ako nije Tajna-PROMJER Lopaticai da li je sve Aluminij ?Hvala
Odg: Zagi alteration Reply #34 – January 25, 2013, 09:51:41 pm Quote from: srepfler on January 25, 2013, 09:47:36 pmOvaj EDF bi bio interesantan Aj nije bilo veceg ? Pa za ovo treba trazit dozvolu od kontrolnog tornja za uzlet Zagi, Mini Titan 325, F5J-N 400 by Beli, MPX Easy Star IIMPX Funjet, Cessna 177 GP-10,MPX FunCub, Robbe Charter, Combat & Slope Soaring Wing, Mini Dex DLG, SpaceWalker, Cirus.Futaba 7C
Odg: Zagi alteration Reply #35 – January 25, 2013, 10:02:15 pm Quote from: tojesvestotrebasznati on January 25, 2013, 09:49:49 pmQuote from: srepfler on January 25, 2013, 09:47:36 pmOvaj EDF bi bio interesantan Koliko se moze vidjeti izgleda veoma dobro,molim te ako nije Tajna-PROMJER Lopaticai da li je sve Aluminij ?HvalaMozda 120, nije jos objavljen specs samo teazer slikica, no jednom ce biti u ponudi.HK facebook objavahttp://www.facebook.com/HobbyKing
Odg: Zagi alteration Reply #36 – January 26, 2013, 01:47:20 pm Uploaded with ImageShack.usjucer mi se srusio program a nisam imao spremljeno pa mi se nije dalo s time ponovo h atto je ovaj motor:http://www.hobbyking.com/hobbyking/store/__18233__Turnigy_D3548_4_1100KV_Brushless_Outrunner_Motor.html
Odg: Zagi alteration Reply #37 – January 26, 2013, 02:34:17 pm ovo izgleda super možda se treba samo poigrati za usis i izlaz zraka za ESC i motor Zagi, Mini Titan 325, F5J-N 400 by Beli, MPX Easy Star IIMPX Funjet, Cessna 177 GP-10,MPX FunCub, Robbe Charter, Combat & Slope Soaring Wing, Mini Dex DLG, SpaceWalker, Cirus.Futaba 7C
Odg: Zagi alteration Reply #38 – January 26, 2013, 02:42:33 pm Quote from: mbalunovic on January 26, 2013, 01:47:20 pmUploaded with ImageShack.usjucer mi se srusio program a nisam imao spremljeno pa mi se nije dalo s time ponovo h atto je ovaj motor:http://www.hobbyking.com/hobbyking/store/__18233__Turnigy_D3548_4_1100KV_Brushless_Outrunner_Motor.htmlTaj motor je dosta tezak, tesko ces izbalansirati taj motor na tako dalekoj poziciji,1100 kv treba vecu elisu pa onda ako zapne krak je veci.Sto tezi to brzi pa mora biti cvrsci, a jedrenje nestaje s tezinom.
Odg: Zagi alteration Reply #39 – January 26, 2013, 02:43:52 pm edf zagi standardni profil ...edf bumbar rclija
Odg: Zagi alteration Reply #40 – January 26, 2013, 09:11:36 pm a kolko kV preporucujete onda ? i koji promjer propa ?
Odg: Zagi alteration Reply #41 – January 26, 2013, 10:36:34 pm meni se ovaj svidiohttp://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21480&aff=4488252200 je bio pre jak 60A 600w na zagi xl35 1400 ok ali nisam dobro pogodio velicinu elise pa je bio neiskoristen. zagi v17x6 je tjeranje u crveno ( pretjerujem nepotrebno), tako da broj manja elisa ili manji pitch na 3s.Taj motor je najmanje duplo nego treba ali volim NTM motore.Sigurno ima i boljih izbora, na koje mozes i prop saver, ali ovo ja koristim.
Odg: Zagi alteration Reply #42 – January 27, 2013, 12:05:44 am znaci ovo bi bilo taman http://www.hobbyking.com/hobbyking/store/__15169__NTM_Prop_Drive_Series_35_36A_1800Kv_875w.html][url]http://www.hobbyking.com/hobbyking/store/__15169__NTM_Prop_Drive_Series_35_36A_1800Kv_875w.html[/url]koji prop uz to ? i da napomenem ponovo, model ako bude radjen iz CF, onda mu ne trebaju nikakve ukrepe i sl. jer bi on bio dovoljno krut, i mozda imao 120g (sam trup bez serva)uzecu ovih dana stirodur (samo da rjesim fax sto imam trenutno obaveze) pa cu izraditi model. itd.
Odg: Zagi alteration Reply #43 – January 27, 2013, 09:10:39 am 28 1800 s 400w cupa iz ruke kod poljetanja a nije pun gas,600w vozim s 1/4 gasa na pola je vertical,bojim se i pomisliti sta bi bilo s 700w na zagiju,no konacan izbor je tvoj.Koristis li neki proracun profil, masa, brzina, tj koje karakteristike ganjas ...Meni je prepravljeni profil mh43 od Plavog puno bolji od klasicnog tzagi12,profil jako igra ulogu pogotovo kod granicnih stall brzina, naravni i kod vecih ali nasporo se najbolje osjeti razlika.Sretno s projektom.
