FrSky X9DA aka Taranis stiže sredinom ovog mjeseca...pošto sam malo razočaran sa 9XR (kojeg sam planirao nabaviti), Taranis je novi kandidat, iako cjenovno nemjeriljiv s 9XR, vjerujem da će biti prava stvar baš kao i 9X kad se pojavio u prodaji.
Features:
* Full Telemetry RSSI alarms (warns you of signal reception problems before disaster can strike)
* Self test of the transmitter antenna
* 16 channels (more when combined with external module)
* 60 model memories
* 64 mixers, 9 flight modes
* 16 custom curves with 3-17 points each, 32 logic switches
* Voice or custom sound alerts
* USB and SD card slot for system expansion
* Long range system capable of up to 3 times the range of current 2.4 systems
* Quad bearing gimbals that are silky smooth
* State-of-the-art open source software
* Super low latency for ultra quick response (9ms)
* Large 212 X 64 backlit LCD screen
* Real-time data logging
* Receiver lock (program locked to aircraft - limited to FrSky receivers running PXX protocol)
* JR Style module bay for additional RF modules and so much more
* Selectable flight mode (1, 2, 3, or 4)
* 2 timers, count up or down, throttle %, talking, etc.
* Trims - Adjustable from course to extra fine with extended and exponential trims
* Standard trainer jack
* ARM Cortex M3 32-bit 60MHz
* Integrates with CompanionTX a FREE computer program that is a transmitter setup buddy. CompanionTX (Windows/Mac/Linux) is used to set-up models with the wizard, save, edit and share your models and settings as well as simulate your transmitter or model setup.
* USB connection for firmware upgrades, sound editing, R/W to the microSD card and integrate with CompanionTX
* Sticks and pots can be calibrated by the end user
* Multiple language support
Inside the FrSky Taranis -- a First looklp,
Marko
