Topic: Novi iMax punjač (Read 2366 times) previous topic - next topic
Odg: Novi iMax punjač
zanimljiv koncept.. to je bazirano na windowsima ili ??
od danas dostupan u HK 85.99$
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=35248&aff=448825
The X200 Touch Screen Battery Charger is a revolutionary new charger design offering the ultimate in ease of use and modern styling. With its huge 4.3" TFT color display and touch screen functionality, you will feel right at home navigating through the menus just as you do on your favorite smartphone or tablet.
This is a true "Smart Charger" with many intuitive features. It can log your battery's charge and discharge curves while displaying the information real-time on the graphic display. The software allows you to save charge profiles for commonly used batteries making charging quick and easy. This charger features many fail-safe functions making it virtually impossible to make a mistake while charging.
The X200 uses an all-in-one charge board that incorporates the most commonly used plugs and balance ports all in one tidy unit. You will never need to go searching for the right charge leads again because they are all right here!
Features:
• Large backlit 4.3" TFT display
• Touch screen functionality
• Supports multiple languages
• All-in-one charge board
• 32 bit processor
• USB port for smartphone charging
• Supports LiPo/LiIon/LiFe/NiMh/NiCd/Pb batteries
• Charges 1~6S LiXX batteries at up to 10A charge rates
• 7 different charge/discharge modes plus a battery checker function
Specs:
Touch Screen: 4.3 inch 480 x 272px
Operating voltage range: 11.0~18.0VDC
Circuit Power: Max 200W (charging) and Max 20W (discharging)
Charge current range: 0.1~10A
Discharge current range: 0.1~3A
Current drain for balancing LiPo: 300mAh/cell
Lithium battery cell count: 1~6
NiCd/NiMh battery cell count: 1~16
Pb battery voltage: 2~24V
Dimension: 148 x 140 x 48mm
Included in box:
Hobbyking X200 Touch Screen Charger
Stylus for touch screen
DC power leads
Tamiya style male to male lead
Alligator clips
PRODUCT ID: 190000002
e, taman naručili 200w x2.... ali dobro... rade i ovi ''stari'' kak se spada... ovaj izgleda moćno, samo opet priče za tu paru... je to sve super ali ja bi punio i vozio, nebi telku gledo... :D
al da izgleda jeeno, fakat izgleda.... :P pravi must have gadget!!!
makar im je ovaj all in one board predobar... samo nema ec5 :'(
da . fora je , samo nek prvo neko proba , pa bumo i mi ....
@jfl2911 , koji si uzel punjač , i ja kemijam da uzmem nešto x2 pa da istovremeno punim dvije po 6s
dx9-xd8-gobac630
