Topic: Molim pomoć Aerial Drop Modul (Read 1423 times) previous topic - next topic
Nabavio sam ovo
i kad sam ga otvoril nastao mi je upitnik u glavi  ??? ??? ???
Kako da to spojim na prijemnik pošto ima X-port na sebi?
Ovo sam našao na netu kako ga je čovjek prepravio na standardni servo priključak
ali mi nije jasno što je sve radio da mu funkcionira
citat
I found that the "Arial Drop Module" made by Hobbyzone (shown above) is electrically compatible with the TTL output signal on the Estes receiver. The Arial Drop Module can be purchased for $19.99 at hobby stores such as Hobbytown USA. The Arial Drop Module has a 4-pin connector interface where pin-1 (with black-striped wire) is ground (negative side of battery), pin-2 is the TTL control input from receiver, pin-3 is not used, and pin-4 is V+ (positive side of battery). To connect the Drop Module to the receiver I cut off the non-standard 4-pin (X-Port) connector and substituted a standard 3-pin RC servo connector (with male pins) available at most RC hobby stores. I then wired a standard 3-pin RC servo connector (with female pins) to the receiver. To be compatible with standard servo wiring I connected the center pin (pin-2) to V+ on both connectors. Making the center pin V+ also prevents damage in case the connectors are plugged in backwards. Pin-1 on the receiver's connector should be connected to the black ground wire on the receiver. Pin-2 should be connected to the red V+ wire on the receiver. Pin-3 should be connected to pin-10 on the RX-2B receiver chip (the 16-pin DIP chip). The Drop Module can be attached to the plane with a rubber band. It holds the parachute with an elastic band and an electromagnet that draws about 75 milliamps. When the throttle lever is pushed down, the electromagnet momentarily shuts off and releases the parachute.
Dal netko kuži to da mi pojasni ili da ga prepravi za ovaj normalni konektor
Evo i vrlo šture upute od ovoga
Marjan
Odg: Molim pomoć Aerial Drop Modul
Da li itko zna ovo spojit ?
možemo se poigrat s time pa vidit jel se može štogod učiniti, javi se
