Topic: X900 Tricopter - moj prvi Tricopter (Read 22327 times) previous topic - next topic
Hobbyking X900 Tricopter Glass Fiber Multi-Rotor Frame
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=28496&aff=448825
Da zapocnem novu temu, dugo sam planirao jednog tricoptera ali nije bio veliki izbor frejmova i repni mehanizam nije bas jednostavan.
Talon mi se svidjao ali je bio mali i dosta skup, nedavno je HK izbacio jedan prihvatljive cijene i odlucio sam i to isprobati.
HK info
Designed from the ground-up by our own engineering team, the X900 Tricopter is a culmination of months of design, testing and material sourcing to provide you with the perfect mix of quality, performance and value. The X900 Tricopter frame is a Hobbyking exclusive meaning you won't find it anywhere else!
The X900 features a very nicely finished glass fiber main frame, shock-absorbing landing legs and folding aluminum arms. The shock-absorbing landing legs are a great feature to handle those rough landings that we all have from time to time.
The integrated tail servo mount is constructed of glass fiber as well, allowing you to mount your favorite micro/mini tail servo for yaw control. The rear motor mount pivots on a dual ball bearing supported shaft providing super smooth and precise movement. As a result, the yaw control is locked-in and very precise while flying.
We offer a full line of multi-rotor electronics such as multi-rotor control board, ESC, motors and more, so it has never been easier or more affordable to get your multi-rotor frame in the air!
All necessary hardware is included. Simply add your own electronics.
Specs:
Front Arm Lengths: 420mm (boom base to motor shaft center)
Rear Arm Length: 450mm (boom base to motor shaft center)
Motor Bolt Holes: 16/19/25mm
Frame Weight: 385g (w/out electronics)
Required:
28-XX or 35-XX brushless outrunner motor x 3
25~40A brushless ESC x 3
High speed micro/mini servo for the tail (digital servo recommended)
10~12 inch propeller (2 standard/1 reverse rotation)
Multi-rotor control board
2650~3300mAh 11.1V lipoly
4CH Transmitter & Receiver
Odg: X900 Tricopter
X666 je bio zrtvovan za dijelove
Odg: X900 Tricopter
Kabl za struju za tricopter mi je napravio 4tm i ovim putem mu se posebno zahvaljujem.
Odg: X900 Tricopter
Servo za rep
TGY-306G Ultra Fast/High Torque MG Digital Alloy Cased Servo 3kg / .06sec / 21g
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22687&aff=448825
TGY-306G Ultra Fast/High Torque MG Digital Alloy Cased Servo  3kg / .06sec / 21g - Excellent 450 Heli & 3D servo.
Model: TGY-306G
Operating Voltage: 4.8V / 6.0V
Operating Speed: 0.07sec.60º/ 0.06sec.60º
Stall Torque: 2.4kg.cm /3.0kg.cm
Weight: 21g
Motor: 12mm Coreless
Potentiometer: indirect Drive
Ball bearing: Top Ball Bearing
Gear: Metal
Case: Aluminum
Connector wire: 220mm
Plug: JR/Universal
Odg: X900 Tricopter
Sta se dobije u kutiji
Odg: X900 Tricopter
Naravno gore ide KK2
Odg: X900 Tricopter
Slikice sastavljanja
Odg: X900 Tricopter
spajanje prijemnika
Odg: X900 Tricopter
spoj na plocicu iz bliza
Odg: X900 Tricopter
spajanje i testiranje repa
Odg: X900 Tricopter
Sastavljen
Odg: X900 Tricopter
vaganje
825 g
plus 1 2200 3s 1005g
na kraju ce ici jos jedna baterija i mozda ponekad gopro
Odg: X900 Tricopter
Pilot
kasnije idu gore loptice i led
