Topic: Spektrum DX8 konačno update za jedrilice (Read 2324 times) previous topic - next topic
Sjetili su se konačno da bi netko želio sa stanicom vozati i jedrilice, do sad je samo na DX10 i na DX18 bilo moguće odabrati jedrilicu kao tip modela.
Nikako mi nije bilo jasno zašto to nisu napravili i sa DX8 koji je jako sličan iznutra sa DX10.
Spektrum™ DX8 AirWare™
Change Log
Version 3.00
8 April 2013
Software Features
• Added full function support for sailplanes (Model Type Sailplane)
Sailplane features include:
• 4 Flight Modes- can be assigned to any 2 switches
Launch
Cruise
Speed
Thermal
• Sailplane Types- 4 wing types available
Normal 1 servo aileron- RES and basic sailplanes
2 servo ailerons- Discuss Launch and Slopes Soaring sailplanes
2 ailerons 1 flaps- Sailplanes with one flap servo
2 ailerons 2 flaps- Full Function Competition and Scale sailplanes
• Tail Types- 3 tail types available
Normal
V-Tail A
V-Tail B
• Motor
Supports motor function on throttle stick, push button or programmable switches
including flight mode
• Camber System
Full trailing edge camber can be adjusted in flight via throttle stick or knob. Different
camber values are available in each flight mode (4). Brake/ Crow is available per flight
mode.
• Camber Preset
4 camber presets available (1 for each flight mode) for flaps, ailerons and elevator
• Flap to Elevator Curve mix
A flap to elevator curve mix can be assigned to a flight mode or switch. Four curves are
available.
• Aileron to Flap Mix
Aileron to Flap mix allows up to four mix values that can be selected via flight modes or
switches
• Aileron to Rudder Mix
• Aileron to Rudder mix allows up to four mix values that can be selected via flight modes
or switches
• Elevator to Flap Mix
Includes offset for snap flap mixing. Four mix values are available
• Six Free Programmable Mixes
• Four Aileron Differential Settings
Selectable in each flight mode or via a programmable switch
• Four Flap Differential Settings
selectable in each flight mode or via a programmable switch
• Elevator Trim Per Flight Mode
Allows active independent elevator trimming per flight mode
Software Corrections
• No changes to Airplane or Helicopter modes
Odg: Spektrum DX8 konačno update za jedrilice
Ako napravim update da li ostaju memorirani modeli ili sve ispočetka ( bindanje,podešavanje postavki za svaki model)???
Naravno, ja sam već 2 puta radio update,od kada sam kupio stanicu, sve ostane.
Taj update je prisutan već neko vrijeme, na nekim austrijskim web-shopovima se prodavao za 30-ak eura. Ali ad je free kak je i trebao biti.
Outrage Fusion 50
Zbunj ???
Svi Spektrum updatei su free, uvedeno je bespla skidanje ako registriraš svoju stanicu na Spektrum site-u.
Naravno vrijedi samo za DX8, DX10 i DX18, budući da se one updateaju preko SD kartice. Slabiji modeli moraju na flashanje u tvornicu ili servis, pa možda na to misliš da se prodavalo za 30 €?
Update uspješan :)
Zbunj ???
Mislim da je bilo za DX8 na D-M-T-u ali se sjecam da je bila crvena kockica tj. nije na stanju.
Sad toga artikla nema, a vjerojatno nikad nije ni bio na stanju, nema smisla ako je moguce skinuti.
Bio je i link na horizonovu stranicu gdje je pisalo da ce taj soft izaci i da ce se doplacivati, te stranice isto tako vise nema.
Outrage Fusion 50
