Topic: Zagi 120 Naked Fpv (Read 14009 times) previous topic - next topic
Zagi 120 Naked Fpv
Hello!
Kako sam izvisio po mjesec dva da nemam sa cime letit dok cekam dijelove, odlucio sam imati barem dva modela koji me vesele kako bi barem jedan uvijek letio.
Pa sam si uz Zagi XL sa svim đinđama slozio ovog Zagija 120 sa minimalnom FPV opremom. Bez gopro, bez osda.
Imam gore rangelink i racewood i siguran sam sigurno bar kilometar. Kako ovo nije skupi setup, hrabar sam nisko letit, izmedu drveca, ispod mosta itd... Za svaki slucaj, ak se razbijem negdje, gps lokator je gore...
Setup:
Zagi (120 cm):
Naravno od Plavog
Motor
RC Timer
ESC
RC TImer
Prop
RC TImer
Servaći
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=662
Batka na avionu
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=25514
Batke ostale napajanje bazne stanice i rangelinka
- testirao sam, cca 2,5 sati dura bazna stanica sa jednom batkom ali sam stavio i ovaj Voltage tester da tuli kad je batka pri kraju da mi se ne desi da ostanem bez struje
http://rctimer.com/index.php?gOo=goods_details.dwt&goodsid=569&productname=
RC
http://www.rangepiloting.com/rangelink-set-p-177.html
Video link
http://www.dronesvision.com/racewood-1-2ghz-500mw-wireless-av-transmitter-red-label/
http://www.dronesvision.com/racewood-1-2ghz-wireless-av-receiver-vrx-for-fpv-wireless-cctv-cameras-red-label/
Antene
Cirkularna na baznoj stanici. Kupio od DavorVŽ. Stock antena na modelu.
Stanica (Slaba točka u setupu ali radi za sad besprijekorno)
http://www.flysky-cn.com/eShowProducts.asp?id=58
Kamera
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16461
Naočale
http://www.dronesvision.com/fat-shark-dominator-modular-design-640x480-fpv-video-glasses-supports-2-4ghz-5-8ghz-vrx-head-track/
Ekran za spottera
http://www.njuskalo.hr/lcd-plazma-tv/lcd-tv-monitor-boji-roadstar-17.8cm-nekoristen-nov-oglas-6611449
Recorder FPV feeda
http://dx.com/p/single-channel-mini-dvr-audio-video-recorder-with-sd-card-slot-53835
GPS Tracker
http://dx.com/p/portable-mini-gsm-gprs-gps-tracker-for-personal-remote-positioning-22599
Težina sa svim džinđama = 1,165 kg
Ovo je maiden! Jos ga moram upicanit, al posebno sam ponosan na winglete!
http://www.youtube.com/watch?v=LboGtL1IaoU
I update - pofarbani Zagi:
Odg: Zagi 120 Naked Fpv
Daglas , odlično sviđa mi se...Ti si hrabar letač... :)
Do sada naljepsi wingleti,  ;)
postaj sliku iz bliza mozes i nacrt.
Zagi 120 Naked Fpv
Ajde u ponedjeljak ih postam!
Evo wingleta:
Po uzoru na experimentalne winglete koje je Airbus testirao
Sam složio ovaj vektorski file. U 1:1 je pa se može printat i paše na Zagi 120.
[attach=2]
A ovako izgleda na Zagiju. Još čeka farbanje...
[attach=3]
Ne moramo diskutirati oko aerodinamici jer stvar leti bez štucanja a izgleda foraaaaa! Beeee!
Hvala,
izgledaju odlicno.
Update! Fotka pofarbanog Zagija i težina.
Zagi 120 Naked Fpv
Čovjeće Srepfler, pa ti živiš na ovom forumu... :)
Zbog posla sam stalno na mailu ( IT) pa mi dodje obavijest da je novi post i samo je klik daleko,
a pises o meni zanimljivim winglecima.
No imas pravo trebao bi smanjiti.
Evo malo basic FPV letenja od ove subote
[move]Highlighti     Highlighti     Highlighti     Highlighti     Highlighti     Highlighti     Highlighti     Highlighti[/move]
     - moj prvi prolazak ispod mosta
     - skoro crash u most, WTF!?
     - zig zag letenje između drveća
     - nisko letenje
     - maltretiranje od nekog lika dok sam na FPVu, brijem da je neki cigo bio ali kako sam imao goggle, nisam mu vidio facu.
Ko voli nek izvoli!
http://www.youtube.com/watch?v=CIsmULTmsmM
Da, treba gsm karticu sa kunama jer radi na smsu.
Ja ga koristim tako da je upaljen ali ne šalje ništa dok mu ja ne pošaljem sms da mi kaže gdje je. Kad primi upit od mene, šalje sms sa google maps linkom na lokaciju. Možeš namjestiti da svako toliko šalje lokaciju ali što više odašiljanja to više smetnji a i to više troši bateriju. Tako da ga ja imam čisto ako model padne da ga mogu naći. Nije to pravi model tracker da ti vidiš rutu koju si vozio itd...
