Topic: Flight mode trim dodan i u ER-9X (Read 1436 times) previous topic - next topic
Sada je moguce imati odvojene trimove za svaki flight mod,
recimo s flapsovima ako vuce malo u stranu...
Odg: Flight mode trim dodan i u ER-9X
to novi er9x ili sto? ili eepe to sam omoguci? nisam bas polovio :D
Novi er-9x a ujedno i novi eepe koji ima tu opciju,
mozes i direkt na stanici ali nije tako pregledno i upute kasne,
moras jedino rucno postaviti ne resetira automatski stare modele.
Modeli koji imaju 4 serva na krilu ce ovo znati cijeniti.
stalno nesto dodaju
ER9x changelog
Please insert a short description of a change by inserting it below this header and
above the previous change.
Format is as follows:
CHANGELOG: 25-APR-2011
description here
CHANGELOG: 28-Apr-2013  MPB
Fix SLOW UP missing bug
Fix default switches bug
Fix voice timer minute bug
Companion patches
Stick scrolling times out if not used
CHANGELOG: 19-Apr-2013  MPB
4.8 compiler used
Mix offset option
Centre beep filtering
Stick Scrolling
Flight Modes
Flash and RAM saving
Mix popup improvements
CHANGELOG: 15-Mar-2013  MPB
Improve Altitude display, voice and alarms
Add Radio cross trims.
Minor flash saving
CHANGELOG: 10-Mar-2013  MPB
Change default to CURVE, not DIFF
Add two more GVARS
Begin to allow alternative languages
