Odg: Mw build logs Reply #60 – June 22, 2013, 04:03:50 pm bolit ce te kad ostanes bez batke daj zatvori tu covjece prvi malo jaci zavoj i otici ce!
Odg: Mw build logs Reply #61 – June 22, 2013, 04:37:19 pm batka je u kucistu nisam bas toliko gloop R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #63 – June 22, 2013, 05:14:07 pm No'es problemos my amigos evo par slikica kako izgleda unutrasnjost ovog legendarnog aviona na 1. je jedna od tih prokletih spajalica sto se tope R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #64 – June 23, 2013, 02:19:13 pm http://www.parkjets.com/su-37-jr2/ moze netko rec sta da uradim s planovima? skinem ih,probam otvorit i ne moze R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #65 – June 23, 2013, 03:38:50 pm Quote from: modernwarfare on June 23, 2013, 02:19:13 pmhttp://www.parkjets.com/su-37-jr2/ moze netko rec sta da uradim s planovima? skinem ih,probam otvorit i ne moze Može, instaliraj neki program za otvaranje .zip datoteka (npr. WinZip, WinRAr, 7zip ( svi OS) ) i kada ga otvoriš imaš folder sa slikama i nacrtima.Damir
Odg: Mw build logs Reply #66 – June 23, 2013, 04:09:23 pm damir okk,good bye F16 R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #67 – June 25, 2013, 08:07:10 pm malo po malo,sutra navecer bi trebo bio maiden (vjerovatno opet ''in the dark'' ) R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #68 – June 26, 2013, 04:47:56 pm Ovo je bilo jednostavnije od F16-ke za napravit i za ugradit elek. tezina je opet rtf 550gr (imam nepreciznu vagu) btw jedini manji problem je bilo cg,moro sam batk-u pomaknit skoro pa izvan one prostorije za elek. i dodo sam naprijed na vrh 2 ekser-a i sad je sve ok R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #69 – June 26, 2013, 09:03:23 pm Nisam ocekivo da ce eurofight-er bit ovako tezak za upravljat 1. let crash 2. let crash 3. let crash i onda su bili tek 4. i 5. uspjesni ali od crash-ova je snimit samo 1.,sutra cu dodat ruder kao sto i pise na planovima nadam se da ce bit bolje posto je ovako extremno trom R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #70 – June 26, 2013, 11:00:56 pm Tomhe Eurofighter maiden flight's ponasa se ko trokrilni ormar al zanimljivo je to sto stvarno ne ide u stall nikako,sutra cu mu dodat ruder valjda ce bit bolje R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #71 – June 27, 2013, 12:03:42 pm ovo je nemoguce naterat da leti R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #72 – June 27, 2013, 11:35:54 pm napravljen dns novi f16 letio sve ok i evo sta sam mu stavio video kako radi ide uskoro R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #73 – June 27, 2013, 11:49:18 pm Rc F16 Falcon bomb drop sistem test i evo kako to radi R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
Odg: Mw build logs Reply #74 – June 28, 2013, 09:41:39 pm Bomb bay radi donekle al uglavnom slupam avion zbog njega (zbunim se dok ga aktiviram) xd nije lose popravit je evo par slika tokom letenja R.I.P modeli: cessna 185, 5xF16 Falcon,2x zagi,Super Bandit,Eurofighter,Mig 29,Mig 29 v1.1,Eurofighter v1.1,Eurofighter v1.2U izgradnji: Tarot fy 450 & F15 Frc Foamies MK2Sada letim: -Ništa
