Topic: APM 2.5 dostupan u HK (Read 2150 times) previous topic - next topic
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=37328&aff=448825
odlicna cijena 71$
i jos vec polemljeni konektori
The ArduPilot Mega 2.5 is a complete open source autopilot system featuring the best selling technology that won the prestigious 2012 Outback Challenge UAV competition. This version is ready to use, with no assembly required. It allows the user to turn any fixed wing, rotary wing or multi-rotor vehicle (even cars and boats) into a fully autonomous vehicle capable of performing programmed GPS missions with waypoints.
Features:
• Arduino Compatible
• Comes pre-soldered (with straight pins) and tested
• Includes 3-axis gyro, accelerometer and magnetometer, along with a high-performance barometer
• Onboard 4 MP Dataflash chip for automatic data logging
• Digital compass powered by Honeywell's HMC5883L-TR chip, now included on the main board
• One of the first open source autopilot systems to use Invensense's 6 DoF Accelerometer/Gyro MPU-6000
• Barometric pressure sensor upgraded to MS5611-01BA03, from Measurement Specialties.
• Atmel's ATMEGA2560 and ATMEGA32U-2 chips for processing and USB functions respectively.
• On board enhancing genuine Molex Micro-USB
Specs:
Dimensions: 67x40x10mm
Weight: 17g
Includes:
ArduPilot Mega 2.5
3pin 2.54mm pitch connection leads x 5
PRODUCT ID: 9387000016
Odg: APM 2.5 dostupan u HK
Kupio još jedan.Prvi radi super,zahvaljujem  srepfleru na pomoći i upucavanju softwera. :)
jeli tko uspio loiter da radi kako treba u verzijama 3.x ...  ?
u-blox gps
apm2
Na dosta site-ova spominju da je ovo kao fake u odnosu na origigi, al ne pusim te fore.
Jel stvarno isti ili... ?
ljudi , pomoc imam jedno pitanje . Nabavio sam quad APM 2,5 sve 5 radi i nema problema , tjst ima jedan  neznam kako da lojter naštimam on mi ne radi ne stoji na mjestu prst mi uvijek mora biti na palici  . Dali sada kompletno moram mjenjat parametre ili ? .
Gps radi uredno , ocita mi ga sve 5 ali , lojter 0 bodova
