Topic: The Boneyard (Read 3591 times) previous topic - next topic
The Boneyard
Evo da neprevodim uglavnom fascinantno,jako dobro se mogu vidjet avioni!
This is just outside the Davis-Monthan Air Force Base in Tuscon, Arizona. It's called the Boneyard, and it's where military aircraft go to die. The arid desert climate is perfect for mothballing aircraft with minimal damage to their components, so they can be cannibalized for scrap later. But these are junk planes, right? Surely nothing valuable is just sprawled out in the desert sun waiting for somebody to figure out what to do with it. Well, a closer look shows the profile of a number of recognizable aircraft, including B-52s (B-52H models cost upwards of $50 million each) and F-14 jets (of Top Gun fame, and each of which cost $38 million to produce). And there are hundreds upon hundreds of them, all just sitting out there, oxidizing.
LINK za Google kartu Aircraft Boneyard, Tucson, AZ - Google Maps
Odg: The Boneyard
kakve oni avione bacaju ...  :(
Sada letim: -Ništa
Odg: The Boneyard
Ne samo kakve nego koliko!
Odg: The Boneyard
Uh kod nas bi već bili u sekundarnim sirovinama,  ::) ::)
 kad si samo zamislim bakar aluminij i još što svega nema tamo, ??? ??? ???
Koliko ih ima staž za penziju bi mogel tam odraditi bez problema  ;D ;D ;D
Odg: The Boneyard
Pogledaj te muzej malo nize na karti ima svasta.
Odg: The Boneyard
Jarun75 kod nas bi ovakve stvari bile jos na duznosti pogotovo F14-ke ...
Sada letim: -Ništa
Odg: The Boneyard
Živio Mario...ne bi se to dogodilo ni kod nas ni nigdje,jer za sat vremena leta jednog F-14,potrebno je 12 sati servisiranja...to ih je i otjeralo u mirovinu.Primjera radi danas jedan F-18 (Hornet),za sat leta treba dva sata servisiranja.
Odg: The Boneyard
tamo mi je bio kum...  slikal se kraj sr71... medju rjedjima je koji su pod strehom (otvoreni hangar).... ostalo nema kaj nema....
Odg: The Boneyard
Da jfl ,SR 71..najbrži na svijetu....vidio sam skoro sve što imaju ...a nema što nemaju.... ;D ;D :D
Odg: The Boneyard
misli sam jedini koji je u hangaru na toj livadi(pustinji), a da se ne vidi iz satelita.... mislim da je to bilo tamo.... vjerojatno jer je bio i u Arizoni, a sjecam se da mi je pričao da ima aviona koliko ti pogled seze.... to je bilo tad kad sam bil klinac... pred petnajstak godina...
Odg: The Boneyard
sad sam bolje pogledao, je, Tucson, Arizona.... to je to.... imaju i Blackbirda tam.... bas me zanima kak zgleda ta cuvena njegova oplata i općenito koliki prostor zauzima, a pojava je i na slici a kamoli uzivo....
Odg: The Boneyard
ako ikad budem toliko uspjesan da odem tamo ne idem bez quad-a  :D
Sada letim: -Ništa
Odg: The Boneyard
 :'( kad vidim sta propada.
Odg: The Boneyard
ehh kad bi to nasi cige vidjeli  :D :D :D
Sada letim: -Ništa
The Boneyard
Ja sam bio u Concordeu i iako ima unutrasnjost neki feeling astronautskog nije me se ni najmanje dojmilo. Totalno ruski štih...
I da, cigo bi napravio da avion "nestane" u sat vremena! Hahaha
