Topic: SD team testiranja (Read 405898 times) previous topic - next topic
Odg: SD team testiranja
Reply #2235
I 30 modela je malo.
Vrijeme je da obrisem neke.
Reply #2236
Nakon sto je prvobitno 3.3v regulator riknuo narucim ja s ebaya samo APM sidepins na akciji free shiping za 34$, najsporiji economy shiping
kao dolazi tek u 3 mjesecu.
Doslo za 7 dana :-)
Local Date and Time[/size]Country[/size]Location[/size]Event Type[/size]Extra Information[/font]
[/size]5.2.2015. 14:05:00[/size]HONG KONG[/size][/size]Receive item from customer[/size][/size][/font]
[/size]6.2.2015. 23:00:00[/size]HONG KONG[/size]HONG KONG AIR MAIL CENTRE[/size]Send item abroad (EDI-received)[/size][/size][/font]
[/size]7.2.2015. 7:45:00[/size]HONG KONG[/size]HONG KONG AIR MAIL CENTRE[/size]Insert item into bag[/size][/size][/font]
[/size]10.2.2015. 15:51:01[/size]CROATIA[/size]ZAGREB 10003[/size]Receive item at office of exchange (Inb)[/size][/size][/font]
[/size]11.2.2015. 13:28:20[/size]CROATIA[/size]ZAGREB 10003[/size]Insert item into domestic bag[/size][/size][/font]
[/size]12.2.2015. 2:46:06[/size]CROATIA[/size]31200 Osijek KRT[/size]Receive item at location[/size][/size][/font]
[/size]12.2.2015. 3:26:28[/size]CROATIA[/size]31200 Osijek KRT[/size]Send item to domestic location[/size][/size][/font]
[/size]12.2.2015. 6:48:27[/size]CROATIA[/size]31550 Valpovo[/size]Receive item at delivery office[/size][/size][/font]
[/size]12.2.2015. 14:44:00[/size]CROATIA[/size]31550 Valpovo[/size]Deliver item[/size]SIGNED BY : SREPFLER MARKO[/font]
[/size][/color]
[/size]Your estimated delivery date is: Thursday, March 19[/t][/t]
[/font][/size][/font][/color]
APM2.6 ArduPilot Mega APM 2.6 Flight Control Board Exterbal Compass w/ Shell[/t][/t][/font][/size][/font][/color]
Reply #2237
Radi bez problema.
Zanimiljivo da je kutija sidepins dosta veca od up.
Ovaj uredno ima jumper JP1 za napajanje preko reglera, popravljeni nije imao.
I jedan i drugi se navode kao 2.6 a uredno imaju kompas i moja predpostavka je da su 2.5.2 s kucistem od 2.6.
Upucao 3.2.2 u oba.
Reply #2238
Ako ima jumper za kompas moguće da je verzija 2.7 kakvu HK reklamira.
Reply #2239
Nema jumper za kompas, ali mislim da ima za precvikati ako se zeli vanjski.
No za avione je ugradjeni vise nego dovoljan.
Meni za avione i vise stima s ugradjenim.
2.7, 2.8 nisam nasao tako povoljno.
Reply #2240
U tijeku je slaganje long flight hexe za lagano FPV-ejanje :)  ...
Motori su 5010, rctimer propovi 15x5, naza lite, frsky djt, afro slim 20A+simonik, 2x5000mah 20c 4s, glodane Al ruke od cijevi 20x20mm....
Nadam se skorom prvotestnom letu kod Makija još ovaj vikend.... ;D
Reply #2241
Osnovni dio frame je gotov...ide fino-montaža... :)
Reply #2242
Kolko se nadas dobiti flight time?
Reply #2243
Hm...računam oko 45-60 minuta s 10000mah 20c 4s  što svakako nije ništa posebno ali za fpv stroj za zezu je sasvim ok.
Može se tu još dosta grama skinuti ali flight time nije prioritet.
U stvari to će biti dobar stroj za testiranje video linkova, antena, frsky antena i sl....
Reply #2244
80 posto kadrova je napravljeno s gopro3, dvoosnim feiytech gimbalom na y6, okti i x8mini....
Zemaljski kadrovi su napravljeni s canon 5d mark3.....
Trenutačno letim s x8 i troosnim zenom na kojemu je gopro3+ s lećom...
Iskreno kada  dobro pregledam uratke najstabilnije i najmirnije snimke su s oktom (cca 810mm), yaw os savršeno mirna i stabilna bez obzira na vjetar, redudancija praktično dokazana leti bez jednoga motora na jakom vjetru, pitch i roll os su s dvoosnim gimbalom kao da je kamera na kranu.
Nedostatak je jedino veličina pri transportu i problem propova u kadru.(sada s lećom to nestaje)
Slijedeći stroj je x12 s nazom v2 + troosni zen, slijedi testiranje....
http://www.youtube.com/watch?v=2GzehqZd4x8
Reply #2245
ljepo , mislim da su tebi trebali dati one pare za novi turisticku slogan  ...
dx9-xd8-gobac630
Reply #2246
Hvala...Uf što bi bilo novih testiranja :) :)
Evo ponovljenoga testa tiger motora koji su na Banginom x8, odlični motori....
Rezultati su na slici....
Reply #2247
a evo i dio sto mi je falio: stanica Futaba 14SG
Stize i ona u SD team na testiranje i review!
Reply #2248
To majstore......lijepo izgleda biti će to dobar setup za letiti....
Tatu batka 16000mah 4s je dosada najbolja batka koju sam imao na testu.Danas opet odletio jedan let s tvojim x8 i ponaša se odlično.
Nakon slijetanja naponska razlika po čeliji nije bila veća od 0.05v što je gotovo ništa...
Prst gore za nju, kupujem prvom prilikom..... :)
Reply #2249
Uskoro test dys 3ax gimbala na hexi LF....ako poleti.
Nakon zena i feiytech ovo je prvi koji je proradio odmah po spajanju na batku.
Kako se ponaša u letu vidjet ćemo..... ;D
