Topic: SKYHUNTER FPV PLANE (Read 67235 times) previous topic - next topic
Odg: SKYHUNTER FPV PLANE
Reply #270
Probaj sa profi fenom možda se stisne.imam ga i ja ne vrijedi ništa.
Kevlar je zakon.
Reply #271
Evo probao, nista od toga, sve se krene pigat... Mozda u vrucem pod vakumom.
Uglavnom, prevara.
Reply #272
Posložio sam elektrniku na stolu i sve super radi.PPM konekcija između rangelink LSR-a i RVOSD-a je fantazija .Koristit ću minimalno ožićenje .
Prvi dojmovi su odlični , satelite nalazi za 30 sec i to u betonu i  kod oblačnog  vremena .Storm mi to nije mogao. No to su samo prvi dojmovi ima još puno toga za testirati.
 RVOSD6 PPM connection for skyhunter
Reply #273
Izvedba nosaća za dva različita motora .
Prvi beverc 830 kv 1000 w 150 g , drugi specijalac T-motor 730 kv 1200w  205 g
Reply #274
Dagi uspio sam iskoristiti belly protector . Za prvu ruku i neizgleda loše .Ako nebude sviralo ide opet kevlar .
Reply #275
Ajde super, ja cu ipak staklo...
Reply #276
izgleda da su kinezi krenuli serijski raditi li-ion batke za rc uređaje .
Pitanje je samo koje baterije stavljaju unutra , oznaka je 18650 ali nema B.
http://www.batterysupports.com/144v-148v-1618650-13600mah-4s4p-lithium-ion-liion-battery-p-280.html
cijena 138 $
Features
Assemble with high quality 3.7V Li-Ion rechargeable battery pack sealed with industrial Blue PVC
Made of 16 Brand-new A grade cylindrical 18650 cells with PCB and poly switch for full protection
Light weight and higher energy density than any rechargeable battery
No memory effect and rechargeable
Longer storage life than NiMH battery
Built-in IC chip will prevent battery pack from over charge, over discharge and prolongs battery life
Perfect for building 14.8V battery pack for bike lighting, DVD external battery and other small electronic devices.
Charged by Li-ion 16.8V Charging Voltage Battery Charger
Technical Specs
Capacity: 13600mAh (full capacity)
Voltage: 14.8V, peak at 16.8V
Dimensions: 68 x 74 x 74 mm (Height x Length x Thickness)
Weight: 750g
Max. Discharge Current: 12A
Charging Voltage: DC16.8V
Off-Voltage:
Over-Charge Protection: 16.8V
Over-Discharge Protection: 11.2V
Could assemble with customize battery plug!
Reply #277
imaju protect PCB pa ti ograničavaju na 12A i onda prekinu strujni krug, kao da ištekaš batku.
vrlo nepoželjno u RC primjeni.
nema balans port? protect pcb nadzire punjenje? loše kada ti kao modelar već imaš punjač koji to radi 5x bolje i brže
+ kako si i sam naveo, ne navode točno koje ćelije su unutra, na netu ima hrpa i 5000mAh a nemaju ni 2000mAh...
tako da ako nisu neke tipa panasonic 18650B i to bez protect PCB-a onda....
koji prop ide na ona T-motor?
zakaj mijenjaš na još niži KV, ciljaš duži FT ili ?
jesi li usporedio u zraku trokraki 12'' s dvokrakim 13''.
jer u pravilu (da me ne bi napali sada neki teoretičari) efikasnost raste s promjerom, ne brojem krakova.
statički test te može zavarati, pošto ne vidiš koji je pitch speed i potisak pri istome...
Reply #278
trokraki 12x8 (mrak mi je bio i na starom sh )
Da duži FT .
Reply #279
jesam . trokraki 12x8 mi je ideala .lp
Reply #280
zanimljivo,
s kojim si ga uspoređivao u zraku?
Reply #281
13 x 6 , ali neuzimam u obzir samo potrošnju nego i snagu guranja i 13 prop mi lupa po travi kod slijetanja .
12x8 trokrak je meni ideala za sh (ecalculator i iskustvo sa livade ), za prvi motor koristim 12x8  klasika ep.
Reply #282
Tom ova dva šarafa se odvrnu ili zavrnu ovisno dali odlaziš sa livade ili se spremaš za let i upikne se kabel od elevatora .Cijela operacija traje 60 sekundi.
Trup sa krilima ide u svaki auto.
lp Laser
Reply #283
Boing je spreman za lansiranje  ;D
Reply #284
Toliko je velik da gopro izgleda kao FPV kamerica na manjim modelima.  :)
Sretno s maidenom,
crolaser ponovo jase.  :) :)
