Topic: Skyhunter FPV od Daglasa (Read 30368 times) previous topic - next topic
Uuuuu evo napokon sam složio Skyhuntera pa da stavim setup i fotke prije nego ga uništim sa maidenom.
Setup:
Skyhunter FPV white:
http://www.bevrc.com/skyhunterwhite-eponew-professional-fpv-plane_p542.html
Ostakljivanje
IZ Hempela kod Chromosovog tornja u ZG je epoxy i stakleni rowing za donji dio trupa, njušku i stabilizatore na repu. Smisao nije da bude oklopno vozilo nego da pojača spojeve na repu i da zaštiti trup od jače trave kod slijetanja.
Konektori za batku
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9572
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=24707
I jedni i drugi su gore. U XT90 je lakše nagurati žice od 5K batke.
Motor
http://www.hobbyking.com/hobbyking/store/__17602__HobbyKing_3542_Brushless_Outrunner_830KV.html
Mrak motor, malo troši na 4S.
Konektori iz ESCa u motor
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=68
Za oblačenje žica
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=3832
Žice i konektori
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=5492
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6904
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9639
ESC
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2166
Prop
Neke ogromne propove mi je Laser dao, kad dobijem od njega link objavim.
Servaći
Corona CS-929MG
Batka na avionu
Za pogon
www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9963
Za video tx i osd
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=25505
Batke ostale napajanje bazne stanice i rangelinka
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=25514
- testirao sam, cca 2,5 sati dura bazna stanica sa jednom batkom ali sam stavio i ovaj Voltage tester da tuli kad je batka pri kraju da mi se ne desi da ostanem bez struje
http://rctimer.com/index.php?gOo=goods_details.dwt&goodsid=569&productname=
RC
http://www.rangepiloting.com/rangelink-set-p-177.html
Nije mi se sviđalo da mi antena ide kroz krilo. Najviše jer onda zapinje pri slijetanju i uništava se. Spojio sam ju na plastičnu vezicu da ju drži uspravno i pričvrstio u krilo sa PU Maxom.
OSD Storm
http://www.bevrc.com/cyclops-storm-osdthe-bestvalue-ahrs-based-osd-with-rtlrth-fucntion_p453.html
Video link
http://www.dronesvision.com/racewood-1-2ghz-500mw-wireless-av-transmitter-red-label/
http://www.dronesvision.com/racewood-1-2ghz-wireless-av-receiver-vrx-for-fpv-wireless-cctv-cameras-red-label/
Kamera 1
Gopro 3 Black kupljen ovdje http://www.visuals.hr/
Kabel za Gopro feed sam kupio sa ebaya
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190858446526&ssPageName=ADME:L:OC:US:3160
Kamera 2
Običnjača za sigurnost ako Gopro zašteka
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16461
Antene
Sad je na modelu stock antena od Racewooda. Poslije probam staviti IBCrazy bluebeam ultra cirkularne na model da vidim jel bolje.
Na zemlji je IBCrazy crosshair
http://www.sierrarc.com/index.php?main_page=product_info&cPath=65_81&products_id=302
http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=165_108&products_id=823
5 km bi moralo bacat jer je taj setup to trpio na Zagiju. E sad, vidjet ćemo da li će biti što bolje s obzirom na veći razmak na krilima od videa do rangelinka.
Gumice za označavanje konektora
Iz Chipoteke.
Šipke za učvršćivanje repa
Laser mi dao, kad dobijem od njega link objavim.
GPS Tracker
http://dx.com/p/portable-mini-gsm-gprs-gps-tracker-for-personal-remote-positioning-22599
Servać za Gopro Pan već tjednima dolazi.
Kad dođe - će da bude ugrađen!
http://www.ebay.com/itm/130741591505
Stanica (Slaba točka u setupu ali radi za sad besprijekorno)
http://www.flysky-cn.com/eShowProducts.asp?id=58
Naočale
http://www.dronesvision.com/fat-shark-dominator-modular-design-640x480-fpv-video-glasses-supports-2-4ghz-5-8ghz-vrx-head-track/
Ekran za spottera
http://www.njuskalo.hr/lcd-plazma-tv/lcd-tv-monitor-boji-roadstar-17.8cm-nekoristen-nov-oglas-6611449
Recorder FPV feeda
http://dx.com/p/single-channel-mini-dvr-audio-video-recorder-with-sd-card-slot-53835
Tronožac za bazu
Običan tronožac za kameru. Na njega pričvršćen komad iverice i onda elektronika.
Kablovi i konektori za bazu
Iz Chipoteke.
Ukupna težina = 2,7 kg
Fotke:
[attachimg=2]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
[attachimg=8]
[attachimg=9]
Odg: Skyhunter FPV od Daglasa
jedva čekam jedno zajedničko letenje .super si ga složio jedino me srce boli kad vidim onoliko kablova na rangelink rx-u ali ok.
sretno i uživaj.
A znam... A šta ću, kad nemam još onaj vaše dekoder ili whatever pa sam osuđen na ovo. Ali sam se potrudio sve to fino posložiti uredno i označiti pa da imam minimalnu šansu za probleme.
Sutra se nadam maiden odraditi pa javim kak je prošlo...
odličan je!  ;)
KEEP CALM AND DRIVE RC PLANES :)
Sretno s letovima , prijatelju... I naravno puno lijepih videa ;)
A sada i avione! :-(
Show počinje.  8)
Fala na podršci dečki, nadam se da ga necu brzo razbit. Dosta mi je vise razbijanja modela...
Javim se nakon maidena!
Dag ,ocjena 5 za perfekciju... 8) LP
Ja sam u petak u ZG. Kada to odrađuješ da se nađemo.
Iskreno nadam se odraditi ranije maiden, ako ulovim malo vremena i ako vrijeme omoguci.
U petak popodne imam nesto dogovoreno ali nije iskljuceno da idemo letit. Bilo bi mi drago! Cujemo se u petak pa vidimo kak stojimo sa vremenom!
Ili možeš s nama na preljevnicu ;D
Maiden mislim da je pametno odraditi ili solo ili sa jednim kolegom. Polako sve pregledati, provjeriti i probati. Letiti cemo zajedno vec!
Dagi provjeri prije leta GPS.
Meni je ccd kamera na ovoj poziciji stvarala velike smetnje.
lijepo slozeno. drago mi je da vas ima pa si mogu mirne duse ukrasti ideje za svoj fpv model.
pet, sjedni  :D
