Topic: Racing quad - Team Hrvatska (Read 1195350 times) previous topic - next topic
0 Members and 9 Guests are viewing this topic.
Reply #2235
[emoji106]
Reply #2236
Hahah kod kuće je nabolje. Odlično si ga provlačio..
A sada i avione! :-(
Reply #2237
Danas nitko nije bio volje za neku voznju a baterije napunio pa sam isao cisto da ih ispraznim. Ali kad stavim 6x4.5 propove onda je puno teze se provlaciti jer cim malo pipnes gas ovaj ko raketa u zrak, hover mi je na 35%. Za to je najbolje 5x4, a i moram smisliti kracu antenu za fpv, u biti s njom jedino i zapinjem.
Reply #2238
Sekile,koju FPV kamericu koristiš,sa kojim sočivom?
Nisko,niže,...šetnja...
Reply #2240
Kolega sa foruma mi je dao dobar prijedlog da slozimo par verzija setupa za minija a da koristimo samo bangood UK skladiste posto nam je zanimljivo jer nema carine, cijene super i ajmo reci brzo stigne. Eto mojih prijedloga
Prvi setup, ja bi ga nazvao - NEMOZE JEFTINIJE
FRAME
http://eu.banggood.com/Wholesale-Warehouse-Diatone-DIY-FPV-250-V2-Mini-Quadcopter-Frame-Kit-250mm-wp-Uk-935005.html
MOTORI
http://eu.banggood.com/Wholesale-Warehouse-ZMR-1804-2400KV-Micro-Size-Integration-Outrunner-Brushless-Motor-wp-Uk-923424.html
PROPS
http://eu.banggood.com/Wholesale-Warehouse-Gemfan-5x3-5030-Propellers-CWCCW-For-QAV-250-240-Mini-Quadcopter-wp-Uk-939133.html
FLIGHT CONTROLER
http://eu.banggood.com/Wholesale-Warehouse-OpenPilot-CC3D-Flight-Controller-STM32-32-bit-Flexiport-wp-Uk-937044.html
Druga verzija, pod imenom - E OVO JE OZBILJNA MAKINA
FRAME
http://eu.banggood.com/Wholesale-Warehouse-H250-ZMR250-250mm-Carbon-Fiber-Mini-Quadcopter-Multicopter-Frame-Kit-wp-Uk-933185.html
MOTORI
http://eu.banggood.com/Wholesale-Warehouse-Sunnysky-X2204-2300KV-Brushless-Motor-CW-CCW-For-RC-Model-wp-Uk-952075.html
ESCovi - vidim da su ovi opto tako da bi trebao neki 5V BEC za napajanje FC
http://eu.banggood.com/Wholesale-Warehouse-ZTW-Spider-Series-12A-OPTO-ESC-With-SimonK-Program-wp-Uk-946402.html
PROPS
FLIGHT CONTROLER
Odlicno za nas pocetnike
jos neki prijedlozi ?
sad bas da nije najjeftinije a da je do nekle kvalitetno ili mozda neka preporuka vece cijene i kvalitete
Reply #2241
Ovaj drugi setup je po meni odlican. Ja i IronicGti vozimo te motore i stvarno ih ne stedimo. Nakon milion padova i zabijanja u sve i svasta jesu ogrebani , ali kad ga zavrtis kao novi. A to je najbitnije u cijeloj prici
Reply #2242
odlicno
a moze jos FPV komponente ?
Reply #2243
Novi akumulatori...  :D
Reply #2245
Ja još ne znam, nisam bacio test, sigurno ovdje ima nekih pilota koji imaju iskustva...
Po karakteristikama bi trebalo da budu dobre jer nisu teške a 1500mah na 30C bi trebalo da bude dovoljno dobro...
Reply #2246
Dobre ce biti batke Gumi, imaju visok C discharge , a to je ful bitno. Vec me par ljudi pitalo za neki jeftini setup za mini quad, jedino sto mogu reci ako mislite slagati minija zaboravite hobbykingi, osim nanotech baterija. i super sto je ovaj lik izbacio bas video o tome
http://www.youtube.com/watch?v=ijIzbK0vYtU
Reply #2247
Bas suprotno, nanodrek baterije su jos najlosije na hobbykingu!
U to cete se uvijerit kada za ozbiljno krenete vuci ampere, s nanodrek baterijama 2200 45/90c dogfighter jedva navuce 150kmh, a sa zippy flightmas 2200mah 40c 218kmh!
To su malo prevelike razlike, a uz to, niti jedna se nezna napuhnut brzo kao nanodrek!
Reply #2248
A meni bas suprotno. Sve zippy koje sam kupio zivo sranje. Pise 35C , nova batka odem u flip a quad mi se zabije u pod, nema struje. Bar one zute 1500 3S 35C. A da ne kazem da nakon minute leta beeper poludi jer su celije pale ispod 3.5V. I na kraju quad padne, ostanem bez slike i tu sam puko. Ok da je jedna ali 3 od 3. Lagano smo ih dokrajcili sarafcigerom. Mozda su ove 2200 bolje ali ovo je prestrasno. I kad sam kupovao te nanoshit slusam ekipa ih pljuje, a rekoh idem probat i totalna razlika. Vidio sam kako kuris svoju 2200 uzivo u avionu i fakat je drzala ali ovo 1500 je koma
Reply #2249
Male zippy baterije nisam probao, ali tipa ove 2200mah iz njih sam vukao i duplo!
Nikada nisam uspio ubiti niti jednu, ali nanodrek vece rikavaju kao lude, mislim mozda jednostavno nandrek ove manjeg kapaciteta su dobre, a kod zippy obrnuto!
Ocito je od serije, do serije!
