Topic: Racing quad - Team Hrvatska (Read 1195428 times) previous topic - next topic
0 Members and 7 Guests are viewing this topic.
Reply #4995
ovako to rade vani....
na dronenationalsima:
http://dronenationals.com/rules/
u britaniji:
http://www.bfpvrl.org/rules/rules-regulations
par zanimljivih odlomaka:
Pilots must adhere to the prescribed launch sequence. No movement before the starting signal. False starts will incur a penalty at the discretion of the Field Marshal or Flight Director. Most standard penalties will be pre-defined before the start of the race and posted. Generally they are defined as:
  • False Start penalty: 5 seconds
  • Not following flight path: 5 seconds
  • Flying in opposite direction of flight path direction: 5 seconds
  • Deliberately attacking or crashing into opponent: 5~10 seconds depending upon severity
  • Other minor infractions as deemed by the Field Marshal or Flight Director
  • Pilots must maintain control of their aircraft at all times and only fly within their skill level. Any pilot who exhibits unsafe flying procedures may be disqualified at any time at the discretion of the Field Marshal or Flight Director.
  • Once pilots have successfully completed all laps, they must return to the start/finish pad, land and DISARM. Pilots must give the Flight Director a “THUMBS UP” that they have completed their flight.
  • Pilots that have crashed at any point during the heat and are unable to resume racing must DISARM their aircraft, give the Flight Director a “Thumbs Down” indication and wait until the heat is over. The airframe will be recovered by the field crew.
  • Pilots must successfully fly through all gates, flags, and other obstacles on the course. If a pilot misses an obstacle, they must safely turn around and attempt the obstacle again. They will have up to two further attempts before being disqualified from the heat. Judges will ride along via FPV with the pilot, and will indicate immediate to the pilot if they must correct any flight path errors. Additionally, the Field Marshal and field observer judges may signal to the Flight Director that an obstacle has been missed. In this case the pilot must immediately and safely return to the missed obstacle and attempt to successfully navigate it.
  • Maximum Ceiling height for this event is 40 feet (12m). Any breach of the ceiling will result in immediate disqualification from that heat. If the pilot receives two breaches of the ceiling height or goes out of bounds at any time during the event the pilot will be completely disqualified from the event. If a pilot has breached the ceiling or has gone out of bounds, the pilot must immediately land your aircraft in a safe location on the field. The FPV Judge, Field Marshal or Flight Director will give further instructions.
  • The Field Marshal has the right to disqualify any pilot for any reason if the pilot or piloting behavior is deemed unsafe or if the pilot has breached any rule or regulation within this document.
Reply #4996
Božić je...
Kad isti dan stigne paket s video prijemnikom i naočalama iz Nizozemske i odašiljačem i kamerom iz Singapura!
ZMR250 - DYS BE1806 - Blueseries 12A - CC3D
Reply #4997
Koje cvike si uzeo
Reply #4998
Ajmo ovako, stvarno mi se ne da tipkat a i vidim da lagano u prepiranje ide :D
OVO ĆE BITI PRVA UTRKA U HRVATSKOJ. JEL NEREALNO OČEKIVATI DA ĆEMO BITI FER IGRAČI I ODRADITI SVE KAKO SPADA??
Odmah ćemo u hodu vidjeti probleme itd...ja predlazem da svaki sudac gleda tipa dvoja vrata i tko nije proletio...ako se ne vratis natrag nego namjerno nastavis - ajde bok, tu utrku si zadnji (tj. DNF)
I Drone nationals pravila su zak***c...5 sekundi kazne za rusenje? Come on! Onda cu sve porusit i kruzat do cilja.....svaka pravila imaju rupe ljudi :)
Reply #4999
Moj prijedlog je da probamo sa manjim brojem pilota. Lakše je pratiti, lakše je zbog frekvencija, više utrka. Tipa 3-4 pilota po utrci i to je to. Oni koji se ne utrkuju mogu se spojiti na nekoga od pilota koji upravo voze i ujedno biti sudci. Definitivo treba staviti neki penalty za ne praćenje staze.
Reply #5000
4 je maksimum sa nasom opremom (vulgaris antene, 600mW špric-mašina i slično) :D
Reply #5001
 1. backspin - 4ch immersion - 5800
2. Ironman  - 7ch immersion -5860 ;D
3. Rockwell
4. Yodaman - 2ch immersion -5760Mhz
5. Sukiyaki
6. Klic
7. Mr.Zedooo - 4ch Boscam 5645
8. Adder E2 5685
9. Kuzma - 32ch 5828MHz
10. Coljo - 8ch 5945
Reply #5002
3. Rockwell
5. Sukiyaki
6. Klic - 5ch immersion - 5820Mhz
8. Adder E2 5685
Reply #5003
3. Rockwell- 3ch immersion -5780Mhz
5. Sukiyaki
8. Adder E2 5685
Reply #5005
Probao sam da bar imamo app:)
Reply #5006
zato je moj prijedlog da nema rusenja... srusis= DNF
sorry.. nemoj rusit i svi sretni..
Denis najsretniji jer nece morat nova vrata radit :D
Reply #5007
Pricam o rusenju drugih a ne o vratima!
Reci ti meni jel mislis da je u Prelogu netko namjerno rusio vrata? Nije...znaci svi smo manje vise diskvalificirani :D
Hocu reci jako je lako slucajno potepst vrata ako se zuris! Ne znaci da si nesto lose napravio...malo mi je preostra kazna.
Bolje da bude reflight ali tipa 5-10 sekundi hendikepa cisto da ljudi to ne rade namjerno. Jedini problem onda je sto ce biti puno reflightova. Treba realno procijeniti, tipa ako lik kasni pola kruga za svima i potepe vrata, nastavio bi utrku bez tih vrata i bok!
Reply #5009
pa u Prelogu nije nit bilo utrke lunjali ste ko divljaci po zraku :D
i da tako je, diskvalifikacija...
mislim gle meni u biti tak svejedno. ak ces podrzavat takvo divljanje po stazi meni fine.. manje kazne meni kad mi se tak nest desi... ;)
al ono, imamo ravno 6 vratiju od kojih redovito nekaj fali kad idemo letit.. znaci i tih 6 je upitno (za sada). doci ces na utrku, neko ce ih skrsit i dobit po tvome neku kaznu u sekundama ili jos gore, radit ce se prelet preko vratiju koda se nis nije desilo.. i ostatak utrke (ili utrka ako ih je vise) ces vozit s polupokrpanim vratima, ili bez vratiju itd.. onda to vise nit nije ista staza i da ne nabrajam sad u nedogled.
nemoj se zavaravat da ces s recenicom "daj pazi malo kak vozis" ili "sad daj 100kn za vrata" nekog urazumit... cast iznimkama..
naravno sve ovo kaj navodim danas nece sprijecit krsenje vratiju da se razumijemo, ali za tak nesto treba bit kazna dost velika. Ako si cito pravila, nigdje se tak nesto ne spominje direktno, znaci to su slucajevi za onog "marshalla" :)
