Topic: Racing quad - Team Hrvatska (Read 1193090 times) previous topic - next topic
Reply #1695
Kakve su reakcije na Micro Titan motore... zna li netko?
Dobavljivi su u EU pa si mislim piknuti.
Ima sad i T po super cijenama, ali su van EU. Jel ima saznanja za EU dilere po dobrim cijenama?
Googlam al mi neide  ::)
Reply #1696
Di si naso micro titan u eu? Ja sam narucivao,ali izvana.
Reply #1697
Evo ga, ali nisam stigao spojit. Stoji doma u kutiji i ceka svoj red :D
Evo usporedne fotke pored jadnog zmr 1804 :)
Reply #1698
Dr.Tom, evo i tebe s malcem, ha?
Koji setup imas i kako si zadovoljan? To je neki manji frame? Takve jos nemamo u temi. Imas neke fotke?
pa s obzirom da je ovo prvi takav zvrk, jako sam zadovoljan,
jer ne znam kako lete neki drugi  :P
setup redom:
sve kupljeno online, bez piljenja i brušenja u kućnoj radinosti
frame: Diatone  http://tinyurl.com/14cmminiquad
pogon: RcTimer  http://www.rctimer.com/product-1131.html
kontroler: CC3D klon  http://www.banggood.com/OpenPilot-CC3D-Flight-Controller-STM32-32-bit-Flexiport-p-937044.html
batka: A-Spec Nano https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=53774
VTX: 600mw Boscam 32ch + njemačka antena http://www.banggood.com/Boscam-FPV-5_8G-32CH-600mw-Wireless-AV-Transmitter-TS832-p-917263.html
RX: RC805 + neka kineska antena http://www.banggood.com/FPV-5_8G-8CH-200mW-AV-Wireless-Receiver-RC805-p-73202.html
kamera za let: ona WDR u metalnom kućištu http://www.securitycamera2000.com/products/600TVL-SONY-SUPER-HAD-CCD-D%252dWDR-Color-Board-Camera-with-OSD-Menu-DNR.html
kamera za snimanje: Mobius naravno  http://www.banggood.com/Mobius-Action-Camera-1080P-HD-Mini-Sports-Camera-Wide-Angle-Edition-p-917817.html
OSD: Remzibi klon  http://www.ebay.com/itm/261497509138?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
LCD: Super duper jako veliki i kvalitetan za 100kn http://www.ebay.com/itm/5-High-Resolution-HD-800-480-no-320-240-Car-TFT-LCD-Monitor-Screen-2ch-Video-/281206263906
više o FPV ground stationu  :D
http://www.flyfreak.net/fpv-i-ap/quanum-diy-ocale-za-sirotinju/msg169142/?topicseen#msg169142
za kratki let dok idem s posla po malu u jaslice, dušu dalo,
taman za održat kondu u prstima tokom zime. :)
uskoro bum probao i ovaj novi fw što je sekile postao,
ovaj za sada stvarno ne drži nikako visinu.
thnx Krešo na PIDovima, možda bu bolje letio s njima.
evo dole mojih PIDOva na kojima sam letio i snimio onaj filmić jučer, i danas jedan koji se uploada.
Reply #1699
Odlican je malac, džepni strojček.
Taj remzbi osd klon, jel to sta valja? Ima nekih podesavanja, i neznam cega, ili je ono, ustekaj, i leti?
Tak nesto me zanima za quada, jeftino, a da funkcionira.
Reply #1700
Dr Tom,možeš li mi objasniti način povezivanja tog Remzibi klona sa USB konektorom. Hvala unaprijed. Evo kad smo kod motora da i ja kažem da su mi danas stigli novi motori. RCX 1806 2400KV. Sutra ide ugradnja. Onako na prvi pogled,baš mi izgledaju dobri,pedantno namotani,čvrsti... A nisam mogao odoliti cijeni na MyRC-u.
Nisko,niže,...šetnja...
Reply #1701
Bas citam te kombinacije sa fake motorima sa bangooda. Ja na quadu imam motore sa multorotor superstore, pretpostavljam nisu fake, a i da jesu briga me jer rade mrak. Bio sam nedavno uzeo jedan sa bangooda za rezervu i bas gledam, ne kuzim bas razliku ili sam corav. Istina ja sam svog sa bangooda platio 18usd, neznam jel tu ima razlike.
Nebitno , malo sam upgradeao malca, nabacio mu kilu ledica, kombinacija plavih i crvenih, MUP edition  ;D , ako me snime negdje mislit ce da sam njihov i slozio sam vibration mount za mobius sa onim veci gumicama i radi zakon. Mobius je inace poznata po tome da prdnes kraj nje ona ima jello, e sad vise nema, Mogu stavit najgore propse i slika super. Jedino nemam vremena za letenje  :o
Reply #1702
a malecki je, stane pod sic i bok, samo batke furam doma na punjenje a i da se ne smrznu po noći u autu...
original OSD je uštekaj i leti ali je i skuplji, ne znam ni koliko nisam gledao, ali negdje se spominju cifre oko 100$(?) ako sam dobro zapamtio
pa sam uzeo jasno kineza kojeg treba malo flešati s bootloaderom, firmwerom i onda podesiti layout,
još malo petljam pa ti javim kada vidim jel sve radi kako treba. (moram flešnuti taj bootloader a nisam stigao)
misliš onaj programator za podešavanje layouta i updejtanje FW-a?
to se ušteka na mjesto GPS-a, njega ištekaš prilikom toga s OSD-a.
bez lemilice sve jasno.
možda se može nekako spojiti i na cc3d pa da imaš horizont, ali koliko sam imao malo iskustva s ovim zvrkom,
tu fakat ne treba puno podataka, na kraju ne vidim ni voltažu jer ciljam da ne poberem stablo,
tako da je vjerojatno dosta i onaj za 10ak$ s HK, super simple osd...
Review: $10 Super-Simple FPV OSD
Reply #1703
Ajd javi kad sredis. Nije lose imat osnovni osd na malcu, a steta stavit nesto skupo i trosit love, posto se lako razvali pri padu
Reply #1704
snimka od danas poslije posla,
stari fw. pidovi su par postova gore.
najluđi mi je prolazak na 5:10, poniranje sa skoro ugašenim motorima.
ponovno baby steps, malo po malo pa nema potrganih propova , za sada :)
second mini quad fpv flight!
2 George, na kraju vidiš malo i OSD-a.
kao i tu, stavio sam novi FW i djeluje da radi ok,
vidjet ću u zraku
Remzibi 1.8 OSD
Reply #1705
E to se trazi, thanks!
Reply #1707
@Majk ,sviđa mi se Tvoje uputstvo za uporabu .... koliko sam samo vremena proveo u autu čekajući zakonitu.... :D :D :D
Reply #1709
Ekipa super su ti osd, ali nevidim koja je korist na miniju. Ajde jedino onaj simple osd koji pokazuje napon, ako nemas telemetriju. Znaci model leti cca 6-7min znaci nemozes daleko,  kreces se uglavnom po nekoj sumici, parkicu, zgradi i tak, koja ti je tu svrha gps podataka osim da te zbunjuju jer zuris u to a ne gledas kuda vozis. Po meni najveci help je onaj lost model buzer ili jos bolje spojis buzer na naze32 i imas istu stvar. Da ne kazem da mi je to hrpu puta olaksalo trazenje malca u grmlju
