Topic: Tko je online na Phoenix simulatoru... (Read 79524 times) previous topic - next topic
Odg: Tko je online na Phoenix simulatoru...
Reply #105
Jel imas pod "Game Controllers" u Windowsima sto? Jel tamo radi?
Reply #106
nista, samo radi tamo na tom thermometru...
Ne znam do cega je...?
A i emulator nece, pise da je TODO stopped working, nezz da ima kakav todo program koji je vezan za taj phoenix ili emulator...
Neko da pomogne ?
Reply #107
Da nemas kakav antivirusni program koji te steka? Ako imas iskljuci ga dok na instaliras!
Reply #109
Evo nesto vezano s tim! To sam pronasao na netu!
Jeff R 1, really thank you!
http://experts.windows.com/frms/windows_entertainm...nnected_home/f/25/t/78002.aspx
So yeah seems this error happens with both PowerDVD 9 & TotalMedia Theatre Blu-Ray packages
If you get the TODO: APPCRASH COMAP.exe errors after you install your 3rd party Blu-Ray package, I found a work around !
http://www.arcsoft.com/forum/forum_posts.asp?TID=3204
(if you read further seems to be related to Reaktek audio, someone has another registry fix)
"Anyway ... here's what you do. Let the application crash at least one time. Then, go into your temp folder (C:\Users\{you}\AppData\Local\Temp) and locate COMAP.EXE. Right-click on it and select properties. Switch to the Compatibility tab. Set the Compatibility to "Windows Vista". Seems to do the trick.
Note also that even if you delete the file, that compatibility setting will still apply when TMT creates the file again next time. So no worries about disk cleanup and whatnot."
Sweet ! Works great for me, perfect.
Reply #110
Jesi li updateao ikada windowse?
Reply #111
hvala svima na odgovorima... Sad je kasno, pa cu probati sutra naprviti sve..
Windows sam updateovo par puta.. Ali nije mi licenciran...
Uglavnom hvala, pokusat ccu ako uspije javim, a takodje i ako ne uspije...
Jos jednom hvala na trudu
edit: nemam foldera temps, imam samo comodo, google i torch....
A da li neko ima rjesenje mog prvog problema, ne ovog sa TODO-m?
Kako da mi prikaze i u game controlers ? Ne samo u PPM thermometer..?
Reply #112
Cekaj jesi ti uopce instalirao PPJoy? :)
U njemu je najveci problem pronaci "kanale" koji rade!
Meni nije radila autodetekcija vec s nabadao dok nisam nasao sto radi.
PpJoy napravi joystick koji Windowsi vide (u game controllers)
Zatim to sa emulatorom "pretvaras" u Interlink kontroler koji Phoenix prepoznaje. Idi po redu.
Reply #113
da, uradio sam sve po instrukcijama...
Sutra cu sve uninstal pa opet instal.. Valjda ce moci..
Reply #114
Jel dolazi tko na sim?
Reply #115
sve sam radio ispocetka..Nece nikako, vidio sam na drugim forumima da j eproblem sto imam win7...
Ima li ko da radi prego ovog emulatora i dongle-a a da mu radi na win 7 ?
Reply #116
Problem Win7 je sa PPJoyem, ne zele otvoriti sve portove...
Ima rjesenja, samo se ne sjecam kako tocno doci do toga, ali Win se dignu u "test" modu i onda je sve moguce :)
Ako i kada nadjem info javim.
Reply #117
Palim za pola cuke!
Reply #118
Evo i ja cu izgleda napokon uspjet slozit updateve, dodjem nakratko cim proradi
Reply #119
Ok!
