Topic: FPV Radjet800 (Read 11979 times) previous topic - next topic
FPV Radjet800
ušteka se batka i u zrak, nema uštekavanja krila i sličnoga,
instant zabava, a i mora biti kada onaj 90'-multi nikako da posisa batku pa malo minuta ostane za avione  :D
setup:
2200 KV  2826 motor
INT http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=12919&aff=262581
EU http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=41745&aff=262581
4.7x4.7 CamSpeed Graupner aircraft world (idući let bu 5x5)
Cyclops STORM OSD (moram se poigrati s gainovima očito)
http://www.foxtechfpv.com/cyclops-storm-osd-v11-firmware-p-688.html
45A YEP ESC,
INT http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=20690&aff=262581
EU http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=42761&aff=262581
1500 mAh 4S Zippy compact batetry,
INT http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21341&aff=262581
EU http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=36158&aff=262581
Turnigy TGY-113MG Metal Gear Digital Servo 2.2kg / 0.10s / 12g,
INThttp://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=24763&aff=262581
EU http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=36330&aff=262581
carbonska šipka 4mm u krilu
715 grama AUW
leti kao po tračnicama, 145 km/h, a penje 20m/s   :)
Odg: FPV Radjet800
Hihi fora fpv komarac!
Odg: FPV Radjet800
rekoh, ajd da vidim kak polijeće u autopilot modu,
uh. skoro fatalna pogreška, gainove zbog brzih serva i živahnog modela treba još smanjiti, dosta.
bilo je drž nedaj, ali uspio sam nabrati visinu i ugasiti autopilot,
probao sam ga još jednom na djelić sekunde u zraku kasnije, koma.
budem smanjio gainove pa vidim drugi puta, a polijetanje jasno na manual modu  8)
720p - nestabilizirano  :D
Radjet800 FPV
Odg: FPV Radjet800
Glavno da su mene "naucili" da taj motor ne moze raditi na 4S... :D
Hvala Tome, samo jos jedan dokaz da se ne treba bojati isprobavati stvari!
Odg: FPV Radjet800
Hahaha suludo se baca! Kako ces ga skucat negdje u low level letenju, vec te vidim! Ali cini mi se da bi bolje bilo da ga slozis low cost, bez storma i icega da ti ga nije zao pa pićiš 20 cm od zemlje...
Odg: FPV Radjet800
Tu je došlo pilotsko iskustvo i umijeće do punog izražaja. Nice Tom. Sada mi je čist žao što više nemaš onog Mesera. Staviti u njega fpv pa se spustiti niže...uh to bi bio adrenalinski udar....
Odg: FPV Radjet800
Ovo stvarno vrijedi vidjeti.  :)
To je pravi FPV, dojam je brze nego u lovcu F16,
treba imati hrabrosti tako sto letjeti FPV,
fantastican video.
Odg: FPV Radjet800
Thnx, bit će još nadam se filmića po sunčanome i snježnome, pa bu i boje bolje,
a i moći ću niže letit, da ne isprobavam odmah sve na maidenu po magli i još svega 200m od poIicijske akademije ;D
kraja filma nema jer kao što se vidi, pojavilo mi se neko crveno upozorenje LOW BATTERY!
ja gledam koji klinac, pa nema storm tu opciju, pogotovo ne u boji,
i kad ono nakon 10 sec ugasi se feed,
na tih -1C i pri toj brzini, na udaru direktnog zraka na nosu modela, se smrzla batka u kamerici i pao napon,
inače doma radi oko 40min, možda i dulje, bila je friško napunjena do vrha.
slično sam primjetio još davno, na turnigy kamericama,
http://www.flyfreak.net/elektronika-i-baterije/md80-kamera/msg35715/#msg35715
a ova ima duplo manju kameru, lakše se ohladi...
 pošto storm radi na 12V(ovdje i 16V radi 4S) izvadio sam srednji pin da se ne uništi kamera, koja tu očekuje 5V,
ali vidim da mi treba dopunjavanje i u zraku tih par minuta, radi hladnoće, pa sam skemijao Y kabel koji daje video out a uzima 5V s ulaza u storm,
tako da sada više nema gašenja kamere u letu,
al bilo je fora, letiš letiš i crna slika, a rth ne smiješ upalit jer nije podešen... ah taj nedostatak vremena bu me koštao ozbiljno jednom, siguran sam!
p.s. Daglas, StormRTH je gore jer letim na kineskom klonu 2.4 prijemnika od 100kn, a ne original hitecu koji javlja kada krenu paketi ispadati,
i onda mogu lako izgubit ili komandu (jer nije 433MHz) ili sliku jasno, pošto je to 5.8 s cirkularnim omnicama,
 a ne long range 1.2 s usmjerenom ground antenom...
btw, i taj kinez radi preduge antene, 31mm  ???  poštucao sam ih na 27mm, brijem da može radit samo bolje
http://www.flyfreak.net/elektronika-i-baterije/hitec-duljina-antene-na-2-4ghz/
Odg: FPV Radjet800
A zoooo... Da, kuzim onda.
Odg: FPV Radjet800
Super doktore.vidim da ima dosta vibracije na stormu.
Nego kaj je sa tornadom??
Odg: FPV Radjet800
2 Laser: Tornado još nije stigao. snalazim se sa Stormom za sada.
flyfreakovi lete i po zimi i po magli  ;D
smrzavanje batke u kameri riješio adapterom za punjenje u letu...
ali danas se ulovio led po krilima u letu!  ??? i kameri  :'(  :'(
HK Radjet 800 FPV - misty day (SHORT)
dulja, needitirana verzija je u linku pri kraju filmića
Odg: FPV Radjet800
nakon tih par testnih letova, sve se pokazalo OK,
pa sam ukopao lemilicom storm u model, kao i gps, koji je poprilično remetio struju zraka nad lijevim vrhom krila(rizik za tip stall)
nažalost krila su jako tanka pa ne mogu progutati VTX i RC RX, tako da oni ostaju vani, ali centralni dio je sada mnogo aerodinamičniji i uredniji,
nema hrpe selotejpa za kameru i poklopac, pa da se sve to raspakirava kao poklon kod izmjene batke,
već je kamera ugrađena u poklopac koji ide na magnete gore/dole, a tipke za storm su lako dostupne kroz otvor za ulaz zraka.
vidjet ćemo jel se primjeti na brzini u zraku prvom prilikom  ;D
Odg: FPV Radjet800
Eh Doktore što bi mi bez tebe i tvojih novotarija..... :'( :'(
And some days you're Icarus.
Odg: FPV Radjet800
a sto si ti ocekivao, temperatura ispod +10, i vidljive nakupine vodene pare, jasno je da ce biti zaledjivanja
Odg: FPV Radjet800
danas se našli Krasny i ja pa malo proletili pred blagdane,
lijepo je vidjet dvije male točkice kak jure po zraku.  :)
sve prošlo 5, idući puta u većem broju nadam se!
