Topic: MKS brushless servaci (Read 3804 times) previous topic - next topic
Evo i MKS izasao sa novim brushless servacima.
Cini se da su dani preskupe Futabe odbrojani.
Uz to izasli su i sa cijelom serijom HV servaca koji rade do 12V
Evo brushless kandidata.
MKS BLS 980 Servo
  Operating Voltage: 4.8V/6.0V
 Operating Temperature Range: -10 to +60 Degree C
 Operating Speed : (4.8V): 0.04sec / (6.0V):0.03sec
 Stall Torque : (4.8V) : 2.5kg-cm (6.0)V : 3.1kg-cm
 Motor Type: Brushless Motor
 Potentiometer Drive: Indirect Drive
 Bearing Type: Dual Ball Bearings
 Gear Type: Titanium Gears
 Case:Aluminum-magnesium alloy shell
 Connector Wire Length: 15cmWeight: 2.12 oz. (60g)
 Wire Length: 15cmDimensions: 40 × 20 × 40 mm mm
BLS 950 cyclic Servo
 Operating Speed : (4.8V): 0.14sec / (6.0V):0.12sec
 Stall Torque : (4.8V) : 9.2kg-cm(6.0V) : 11.5kg-cm
 Case: Aluminum-magnesium alloy shell
 Wire Length: 15cm
Usporedba sa ostalim BLS servacima
BLS SYSTEMsec/60(4.8v)sec/60 (6.0v)kg/cm(4.8v)kg/cm(6.0v)A/D BIT
MKS BLS 9800.040.032.53.116
FUTABA BLS 2510.06 3.8 16
MKS BLS 9500.140.129.211.514
FUTABA BLS 4510.140.19.610.614
SAVOX 750TG 0.09 712
SAVOX 550TG 0.07 312
760us Systemsec/60(4.8v)sec/60 (6.0v)kg/cm(4.8v)kg/cm(6.0v)
MKS DS7600.0290.0236.58.12760/560HZ
MKS BLS 9800.040.032.53.1760/560HZ
MKS BLS 89100.054 2.01 760/560HZ
FUTABA BLS 2510.06 3.8 760/560HZ
FUTABA S92560.06 3.4 760/560HZ
FUTABA S92510.07 3.7 760/560HZ
Detalji na
 http://mks-servo.com.tw/servo-01.htm
Odg: MKS brushless servaci
Imas li mozda barem orijentacione cijene,
vise zbog drugih,hvala
Nema jos nigdje cijena :(
