Topic: Karike od Franka C Bowmana (Read 3924 times) previous topic - next topic
Pošto ću naručivati karike za svoj motor DLE55RA, da li je tko zainteresiran za nabavu istih,
Pitam to zbog Shipinga da ga podjelimo, ja ću raditi narudžbu za 5 dana tj najkasnije se možete javiti do 14.02.2014.
Marjan
Odg: Karike od Franka C Bowmana
Evo ako će netko biti zaiteresiran za karike
S Frankom možete kontaktirati na Email: ringmaster46@msn.com
Karike koje ima na raspolaganju su ove:
** I also make special rings to order, ask for prices**
Abatar 120 4/C
Ace Twin .64
Aero .35
Aerovat 20cc (pin), 65cc (pin)
AGM 30cc (pin)
Aircom M61 (pin)
Air-O .45
Anderson Spitfire .65
Area 51cc (pin)
Asp .52 4C, .61 (pin), .65 4/C, .80 4/C, .91 4/C, 180 (pin)
Atomic 60 Don Sohr
Atwood .49, .51, .63
Avion Mercury 1.609
Avistar .60 (pin)
Bantam .16
Bat .19
Bennelli 65 cc (pin) motorcycle
Berilli 36 cc (Pin) $12.00 ea.
BME 3.5 Twin (pin), 100 Twin (pin), 105 Twin (pin), 110 twin (pin), 58 cc (pin)
Brillelli 60 cc (pin)
Brison 2.4 (pin), 3.2 (pin)
Brown Jr. .60 cylinder sizes vary (send Piston & cylinder for proper fit & correct ring)
Brownie .29
Bushwacker 37.7 cc (pin) Sears
Bunch .45, .49
Byron 50cc (pin)
Cameron .15, .19
Cave Cobra
Chung Yang 29cc (pin)
Cleveland Tom Thumb .45
Comer 50cc (pin)
Como .29 (pin), .40 (pin), .51 (pin), .90 (pin)
Contestor D.60
Copperhead 45cc (pin)
CRRC Pro 26cc offset pin notch, CRRC 26 centered pin notch, 40 cc (pin), Pro 45 cc (pin), GF 50 i (pin), GP 50 R (pin), GF 55 Twin (pin)
CS .53 (pin)
Cub Cadet 25cc (pin)
DA 50 (pin)1.681 Bore, 50 R - L (pin) 1.678 Bore, 60 (pin), 75 (pin), 85 (pin), Older 100 twin (pin), Later model 100 L twin (pin), 120 twin (pin) 150 Twin (pin), 170 Twin (pin)
DL 50 cc (pin)
DLA 32 cc (pin), 56 cc (pin), 50cc (pin), 112 cc Twin (pin), 116 cc Twin (pin)
DLE 20 cc (pin), 20RA (pin), 30 cc (pin), 35 RA (pin), 55 cc (pin), 60 Twin (pin), 111 Twin (pin), 170 Twin (pin), 222 4 cylinder (pin)
DM 55 cc (pin)
DME 100 Twin (pin)
Don Marine Engine
Dooling .29, .61, Yellow Jacket
Double Star .61
DZY 48 cc Twin (Pin)
Echo 16cc (pin), 21cc (pin), 21.2 cc (pin), 24.4 cc (pin), 30 cc (pin), CS-3000 (pin), CS 302 (pin), 50 cc (pin), 65 cc (pin)
Edco Sky Devil .64 Old or New (RJL) state which one?
Elf Andrea Heine Repo
EME 35cc (pin), 60cc (pin)
Enya 3.5 (pin), .30 SS (pin), .35 X (pin), .40 X Dykes (pin), .40 Dykes model 6002, .40 4/C, .45, .45SS (pin), .46 4/C,.49 X (pin), 50SS (pin),.53 4/C, .60 4/C, .60 X (pin), .60 standard, .61 CXLR rear Ex.(pin), .61CXRS side Ex.(pin), .80 X (pin), .80 4/C, .90 4/C, 120 4/C, 120 R 4/C, 1.55 4/C, 240 4/C Twin $11.00 ea.
ETA .29
EVOlution 26cc (pin), 33 GX (pin), 35 (pin), 40cc (pin), 45 (pin), 150 Twin (pin)
EVRA 190
Forster .29, .31, .88, .99
Fox 36 Sand Cast (pin), .40 Sch., .45, .50, .59 .047 thick ring and .030, .59 long shaft Ign., .60 Blue Head, .60 Eagle, Eagle II .60 (pin), Hawk
Red Head .60 (pin), .74, .78, 120 Twin (pin), Gas Bore 1.439 ? (pin), 2.4 40cc gas (pin)
FPE 4.2 69cc (pin)
FTL 52 cc (pin)
Fuji 32cc (pin), 43 cc EI (pin), BT50 SB (pin)
GMS .61 (pin), .61 Dykes (pin), .76 Dykes (pin),.76 Std. (pin), 1.20 Dykes (pin)
GP 61 (pin), 88 single (pin), 123 Twin (pin), 176 Twin (pin)
Gutbrod 440cc (pin) Bolens Snowmobile
Hassad Blue Streak .64
HB .21 Dykes,.25 Dykes, .40 PDP Dykes, .40 Black Head (pin), .50 Dykes, .61 (pin), .61 Dykes
Hiller (Car)
Hirobo 36 (pin)
Hirth 338 Snow Mobile Model 194 R (pin)
HK 24 (pin)
Homelite HK-24 (pin), 25 cc, 30 cc (pin) old .060 thick pin centered (press in ) , 30cc newer .030 thick (pin), 30cc new style Off set pin, 33cc (pin), 35cc ring butts up to pin, 38cc (pin), 40.6cc Super EZ Chain Saw, 42cc (pin), Super Mini Chainsaw Dykes (pin), 45 (pin), 50cc (pin)
Honda SA 50 (pin)
Horner 3.7 Twin (pin)
Hornet .19, .60
Howler .60 (pin)
HP .21 4/C Dykes ,.40 (pin) , .61 Standard (pin), .61 R.I. Silver Star (pin), .61 Dykes (pin) Blk Case Gold Hd.
Hurluman 60
Husqvarna 2100 (pin) Chainsaw Pin needs pressed in 1/2 way
Irvine .20 Dykes, .25 Dykes, .36, .40 Pylon Dykes (pin), .40 Standard (pin), .46 MKII Q46 Dykes, .61 Dykes, 120 Dykes, 150 standard non pin.
JBA 15cc (pin)
JC Evo 23cc (pin), 28cc (pin), 30cc (pin) older 1.418 Bore, 30 cc (pin) newer bore 1.420, 60cc (pin), 100 cc twin (pin), 1.20cc (pin)
John Deere 100 G
Kavan MK 50
Kaw T5A 60cc (pin) Artic cat Snowmobile
Kawasaki 22cc (pin)
KDC Kioritz 21.2cc (pin), 23.6, 25cc (pin), 30cc (pin), 58cc (pin)
K&B .35 Dykes, .40 Dykes, .40 S Dykes (pin), .61, .61 Dykes (Lee Custom), 1.35 (pin), 1.5 (pin)
Kometa .29
KPV-100 single Dykes upper (pin), Standard second ring offset (pin)
Kraft .61 (pin)
Kratmo 10cc, 4A Ignition
Kromo 180 Twin (pin)
Laser 61 4/C
Lewis 60
M&R 100cc Twin (pin)
Magnum .52 RFS 4/C, .53 XL 4/C, .61 XL (pin), .61 4/C, 70 RFS 4/C, .91 XL 4C, 120 4/C, 120 (pin), 120 AR (pin)
Mall 7 Chainsaw (pin)
Maloney 100 (pin), 125 (pin)
McCoy .09, .19, .19 Dykes B.H., .21 Dykes Car, .29 all versions, .29 Dykes B.H., .35 Dykes B.H., .36, .40 Dykes B.H., .49, .55, .60, .60 Dykes
McCulloch 15cc ? (pin) 1.024 Bore, 21cc (pin), 21cc 60SX (pin), 25 CC (pin) MDB 90 Leaf Blower, 28cc, 32cc (pin), 50cc (pin)
MDL 28cc (pin)
MDS .61 Dykes (pin), .78 (pin), 1.48 (pin), 2.18 (pin)
Merco .40, .49, .49 Dykes, .50, .61, .61 Dykes
Micron 60
Mintor  NO LONGER MAKE THESE REMAINING STOCK 1/2 Price WHILE AVAILABLE
MLD 28 (pin), 35cc (pin), 70cc twin (pin)
Moki M .51 (pin), .61 (pin), 1.20 (pin), 1.35 (pin), 1.50 (pin), 1.80 (pin), 2.10 (pin)
MT 42cc (pin), 50cc (pin), 57cc (pin), 65cc ? Twin (pin)
MTD 25cc (pin)
MVVS .40 Dykes (pin)
NGH9cc (pin)
O&R Industrial Motor 1 HP
OPS Maxi .30 (pin)
OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .30 fs 4/c, .32 (pin), .37 H (pin), .40 H Dykes, .40H Standard, .40 H (P) Pylon, .40 FS 4/C, .40 SF (pin), .807 bore, .40 SR (pin), .40 FSR .835 Bore (pin), .40SR Dykes (pin), .45 FSR (pin), .45 FSR Dykes (pin),.45 RSR Dykes, .46FX (pin), .46SF (pin), .46 SF-H (pin), .46 4/C, .48 4/C Surpass, Max .50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX & SXH (pin), .52 4/C surpass, .55 Hyper (pin), 55 AX (pin), .58, Max-H .60, .60 FS 4/C, .60 FSR (pin) .9445 Bore , .61 SF .9055 Bore (pin), .61 FS 4/C, .61 SX (pin), .61 SXH (pin), .61 RP (pin), .65 RSR (pin), .70 4/C, .70 SZ-H (pin), .75 4/C Surpass, .75 AX (pin), .80 FS 4/C, .80 H, .80 Dykes (pin), FS.90 4/C, .91Surpass 4C, .90 FSR (pin), .91 FSR (pin), .91 FX (pin), .91 SX H (pin), .91 HZ (pin), .95 AX (pin), 105 HZ-R (pin), 1.08 BX-1 (pin), 120 4/C, 120 twin 4/C, 120 AX (pin), 140 RX (pin), 160 FX (pin), 160 4/C, FS 200 4/C, BGX-1 3500(pin), 33 GT Gas (pin)
Peak .65 (pin)
Pioneer Grass Trimmer Model B 440, 42cc (pin)
Poulan 15cc (pin), 25cc (pin), 25cc Featherlite (pin), 32cc (pin), 35cc (pin), 42cc (pin), 42cc Wildthing (pin), 46cc (pin), 54cc (pin), 60cc (pin)
Price Midget
Profi .40 (pin), .61 (pin), .76 (pin)
PTE 36cc (pin), 72cc Twin (pin)
Quadra Aerrow QA1 300 BX (pin), 35cc , 40cc (pin), 42cc (pin), 50cc (pin), 52cc (pin) ?, 100cc Aerrow (pin), 150 Twin (pin) , 200cc Aerrow Twin (pin)
Quick Draw 26cc (pin)
RCB 50 (pin)
RCG 50 (pin)
RCGF 15cc (pin), 20cc (pin), 26cc (pin), 32cc (pin), 40cc Twin (pin), 45cc (pin), 50cc Twin (pin), 55cc Single (pin) .059, 55cc (pin) .046, 62 cc (pin)
RCS SV-17 (pin), 26 cc (pin) 2 ring, 1.40 (pin), 1.8 30cc (pin)
RCV 60-SP, 120-SP
Red Lion 58 (pin)
Ross .60 Dykes (pin), .60 opposed twin Dykes (pin), .61 (pin)
Rossi Speed .60 old, .60 (pin) .021, .61 (pin) .023, .65 (pin) .0235, Speed .65 (pin). .90 (pin)
Roto 3.5 Vi (pin)
Rowell .60
Royal 40 (pin)
Ryobi 26 mm Bore EJ 100 (pin), 31cc (pin) older .064 thick, 31cc (pin) older .047 thick, 31cc latest model (pin)
Sabre .49
Sachs 2.0 (pin), 3.2 (pin) offset, 3.2 (pin) centered, 5.8 (pin), 80B (pin)
Saito FA .30, FA .40 , FA .45, FA .50, FA .56, FA .60 Twin , FA .62, FA .65, FA 72, FA .80, FA 82, FA .90 Twin, FA .91, FA 100, FA 120, FA 125 Golden Knight, FG 20 125, FA 130 TD Twin, FA 150 .0585 thick, FA 150 .039 thick, FA 180 , FA 270 Twin, FA 300 Twin .0585 thick, & .039 thick.
Sap-180 HP 1.2 (pin)
Scott Thunderbird
Sears Weedeater, Bushwacker,18cc, 21cc, 25cc, 25cc TWC Leaf Blower, 37.7, all pinned, 1966 Allstate Motor Cycle engine made by Puch (pin), 175 cc twin Allstate (pin)
Shindiawa 33cc (pin), 416 Chainsaw (pin), 500 Chainsaw (pin)
SIFK 29cc (pin) AKA CY, Chun Yang
SK .90 (pin)
Skil chainsaw (pin)
Sky Chief .53
Solo 2/C tiller approx. 20cc (pin)
Spe 25.4 (pin), 26 cc (pin), 40cc (pin), 45cc (pin)
Stihl 25.4 (pin), 30cc (pin), 36cc 4/C, 028 Chain Saw 44cc (pin), 45cc (pin), Super 45 (pin), 57cc (pin), 066 (pin), 62cc (pin), MS 440 Chainsaw, MS 441 Chain saw, 70cc (pin)
Super Tigre G20.15, G20 .19, G20 X.25, S .29 (pin), G21.29 old, .34 (pin), .40 Bullring, S.40 (pin), G21.40 std., G21 .40 Dykes, G21.46 std. ,S.45 (pin), V.45, X.45 (Pin), G21 .46 wide Dykes, G.46, G .46 Bullring, V 51, G51 (pin) Italian, G51 (pin) China, V.56, V.56 Dykes, V 60 light case .044 or .047 top to bottom measurement, G24 60 Old, G 60 Bluehead, X60 (pin), V.60 wide & narrow Dykes, S.61
(pin), G.71, S.75 (pin) Italian, S.75 China, G.90 (pin) Italian, G.90 (pin) China, 2000 (pin), 2300 (pin), 2500 (pin), 3000 (pin) Italian, 3000 (pin) China, 3250 (pin) Italian, 3250 (pin) China, 4500 (pin)
SV 17 (pin), 26cc (pin), 50cc (pin)
Syncro B-30, Syncro ACE, Syncro ACE Special
Syssa 30cc (pin)
Tartan 1.34 (pin), Twin .77 (pin)
TBM 26 cc (pin)
Tech 23cc (pin)
Technipower 7 Cylinder radial, B series, 9 cylinder
TGY 26cc (pin)
3MM 53 TOC (pin), 150 Twin (pin)
3W 26cc (pin), 53cc (pin), 80cc Boxer Twin (pin), 75cc (pin), 85cc (pin), 100cc Twin (pin), 150cc twin (pin),170cc twin (pin)
Thunder Tiger .39 (pin), Pro .50 H (pin), .53 Red Line Heli (pin), .54 4C, .91 FS 4C, Pro .91 2C (pin), Pro 120 (pin)
TMM 106 Twin (pin)
Toki .40 (pin)
Torch 40cc (pin)
Troy Bilt 31cc (pin)
Tune Hill .36 (pin)
Turnigy TR-26HP (pin), 30cc (pin), 50cc TR-50 HP pin), 52cc (pin)
Ueda .45, .61
US 25cc (pin)
Veco .19 Dykes, .21 Dykes, .50 Dykes, .61, .61 Dykes
Vega 10cc, 91 4/C
Vlvatam 2.5, 5cc
VVRC 20 (pin), 40cc Twin (pin)
Webra .32 Speed Dykes (pin), 35 (pin), 10 ccm, 6.5 (pin), .40, .40 (pin), .40 Dykes (pin), .50 Dykes (pin), 52 (pin), .55C AAR Red Head Heli (pin), .61, .61 (pin), Speed .61 FS (pin), Speed .61 F Dykes (pin), .61 Dykes (pin), Speed 70 (pin), AAR .75-P5 (pin), T480 4C Dykes, .91 (pin), 91 P-5 (pin), 120 Dykes (pin), 1.2 LS (pin), 91 T 4.90 (pin), R-145 (pin), 150 Speed (pin), 35cc? Bully (pin)
Weedeater 18cc (pin), 21cc (pin), 25cc (pin) 1.358 Bore, 25cc (pin) 1.380 Bore, 25cc (pin) 1.359 bore, 28cc (pin), 32cc (pin)
Weedwacker 25c (pin)
Westbury Atom III
XYZ 20cc (pin), 26cc (pin), 53cc STS twin (pin), 52cc single (pin)
Yamaha 30cc (pin), 50cc (pin)
YDA 56 (pin)
YS .50 ST,.61 Long Stroke (pin), .63 4/C, .80 H (pin) 2C, F.91 AC 4C, .91 2C (pin), 110 4/C, FZ-115S, F-120, 140-L, FZ-115S Crankshaft seal ring, (120 SC, 140L, DZ 160) Crankshaft Seal Ring
YW 24cc single & 48cc Twin (pin)
ZDZ 40 (pin), 50 NG RV (pin), 60 RV (pin), early 80 RV (pin), later 80 - J model (pin), 90 - 180 twin (pin), 1.05 single (pin) 2.10 Twin (pin)
ZEN G270 (pin) AKA Chung Yang
Zenoah G20 (Pin), G23 (pin), G26 (pin), G38 (pin), G45 (pin), G62 (pin), Z445 74cc Twin (pin), GT-80 Twin (pin)
Zimmerman inline 4 cylinder
