Topic: PRIJATELJI JEL SE DOGODILO OVO KOME ...JEL OVO MOGUCE (Read 4181 times) previous topic - next topic
Odg: PRIJATELJI JEL SE DOGODILO OVO KOME ...JEL OVO MOGUCE
kaj se zalis :D
kaj se zalis :D
ma naprotiv  nezalim se...ali sam iznenaden...a nemogu ni vijerovat da se to moze dogoditi
Letim suncu pravo
Znači kontroler i motore si dobio gratis  :) A vjerujem da se nebi žalio da si dobio još i kameru uz to gratis  :D
 ☆Description☆
Features:
- Simple structure and light weight,CNC aluminum alloy structure
- Brushless motor direct drive
- With anti-vibration rubber balls,easy to adjust
- Compatible with Gopro 3,2,1
- need 2pcs 2208 motors and brushless gimbal controller for work(not including)
- with motor protector which can help heat dissipation
Package included:
-ONLY
1 x aluminum gimbal
4 x anti-vibration rubber balls
1x  Fixed blue tie
Need  2 motors(Recommended 2208 70T without outside shaft) & 1 brushless gimbal controller(w/IMU) more for working
not including the camera!
it needs to be assembled( screws recommended use glue)
If you are  are beginner for the Brushless Gimbal Controller,you need learn how to use the Brushless Gimbal Controller first.
DJI Phantom Gopro 3 CNC Metal Brushless Camera Gimbal Frame
(Note: Does not include pictures of the motor only as a reference)
 ☆Description☆
Features:
Package included:
-ONLY
1 x aluminum gimbal
1x  Fixed blue tie
Da, gratis motori i kontroler...pa da je i kamera stigla nebih to mogao podnijeti nikako, vrato bih jer nisu ni oni neposteni ne bmislim samo na ovaj moj slucaj...inace su uvijek bili korektni..recimo stigla neispravna baterija i poslali su novu i netrazeci da se njima posalje ta neispravna..ali vijerujem da nece propasti Kina za ovako nesto...Mozda netko treba isto ovakav gimbal pa nek proba od istog prodavaca mozda tako salju..tko ce ga znati ...?
Letim suncu pravo
Ma znam Baca, to sam se salio, meni su isto uvijek sve fer i korektno riješavali, jednom kad mi je paket jako kasnio tražio sam povrat novca, dobio sam odmah odgovor da me zamoljavaju da se strpim još tjedan dana i reko ajd strpit ću se još tjedan dana i stvarno je došao, ali sam zato dobrano znao izgorit od ovih naših carinika i to vremenski i novčano  :)
Da ,da.. to ti vijrujem ..vece probleme imamo sa nasima kad nesto narucimo nego sa prodavacima..mozda ce se  situacija  jednog dana popraviti ali otom potom i dalje cemo trgovati na ovaj nacin... kontroler sam narucio u drugoj trgovini pa cekam sad i njega ali dobro je opet od viska glava neboli....a sad idem malo to sastavljat da vidim kako šljaka...Frenki pozdrav i naravno shvatio sam to kao salu..
Letim suncu pravo
Pozz kolega je kupio ovaj gimbal ali sve u paketu i sa nekim lijevim kontrolerom ... Sad problem je u tome sto kad se ukljuci nema nikakvog tona nego gore plava i zelena lampica cjelo vrijeme (pored zelene na plocici pise PWR a pored plave nema niceg) i samo se motori trzaju...Sta da uradim i najvaznije kako? Pomozite  ::) :-[
Sada letim: -Ništa
Upravo gledam,sve konponente na ovom gimbalu i tvojem baca su iste tako da pomozi ako znas ...
Sada letim: -Ništa
e hvala ti,u roku od 1h sam skinio oko 10 programa i svakakvih stvari i opet nikakvog pomaka ... budem sad ovo isprobao,ako uspijem bit ce dobro  :)
Sada letim: -Ništa
jel to kupio ovaj od 20$ ili onaj od 80$?
80$
Sada letim: -Ništa
