Topic: Remzibi's OSD (Read 2219 times) previous topic - next topic
Remzibi's OSD
možda je neko od vas i pratio na rcgroups, a za one koji nisu:
http://www.rcgroups.com/forums/showthread.php?t=921467
inaće kontaktirao sam remzibi-a, i poljak kaže sljedeče:
Code: [Select]
Hello
Thank you for interesting .
I will ship OSD immediately after payment .
MAIN webside : http://sites.google.com/site/remzibiosd/
So price for set is 59EUR (about xxxUSD depends of exchange rate EUR/USD , can be more or less) including :
- OSD assembled and working unit (programmed last software version what I wrote) , board project v1.2 , ADC2(RSSI) and ADC6(current sensor) inputs are prepared for use
- USB cable for communication Prolific
- GPS module 10Hz (16x16mm) on PCB adapter, new firmware, baudrate 38400 - that small one as on picture (this one is reccomended , as all configuration made by OSD are wrote for this model of GPS to get maximum advantages and accuracy).
- cables included (power supply , ENGine voltage measurement , video in/out)
- PCB for DIY current sensor or used as power board
Plus about 3,5EUR of paypal charge per unit .
Delivery and packing cost worldwide is about 7EUR .
So total with delivery let be 69EUR (about xxxUSD depend of exchange rate EUR/USD , can be more or less) . I will deliver by registered letter after payment .
If that is OK for you , then my paypal account is remzibi1@xxxxx
Any questions ? - just ask .
I must say that not good english (nor polish) manual is wrote yet , so till now you must base on that what is wrote on forum rc-cam.info and RCgroups , also in configuration program is online help button - use it . I strongly recommend to read it .
Those who reading it , have not problems using OSD - so I hope you also will .
Configuration software to dowload : http://www.happykillmore.com/Softwar...etup/Setup.exe
Help webside (done by HappyKillmore) - http://www.happykillmore.com/Software/faq.asp
More help (done by me) - http://rc-cam.pl/viewtopic.php?t=178
Latest firmwares, drivers and news also on this web side
my address :
xbigniew xierzbicki
ul.Rozxana xx
x4-230 Rumia
PxOLAND
regards
remzibi
PS - Cost for incomplete set :
OSD with USB cable but without GPS module - 50EUR
OSD with cables but without GPS and USB cable - 44EUR
This include Paypal charge and packing and worldwide delivery cost .
inaće imam GPS modul sa miniOSD-a, a i mogo bi se nazin signal koristit (isto kako ga na minimosd spajaju), zato je na kraju napisao cijenu bez gps-a
ima li itko kakva iskustva s ovime, ili zna nekoga ko ima :)
stvar izgleda zanimljiva i nije precijenjena kao neke brendirane alternative
