Topic: Stanica HK T6A V2 6ch-molim za pomoć... (Read 2194 times) previous topic - next topic
Molim za pomoć.Navedena stanica je nova,radi,ali svaki put kad ju upalim moram nanovo namještati snagu gasa.Postoji li neki način da ostane umemorirano za stalno? :-[
Odg: Stanica HK T6A V2 6ch-molim za pomoć...
Mislim da je do reglera, treba iskalibrirati gas!
Regler se ne može kalibrirati(graupner navy v30r-brushead),svi ostali kanali mi rade ok :-[
Ipak,Coljo,hvala ti.
Si citao manual od reglera?!
Probaj ovo sta tamo pise :)
Setting the Standard Mode / First operation
1. Make sure all the cable leads are properly connected.
2. Turn the transmitter on and check the servo travel of the throttle channel which should be ±100% or, with
Multiplex R/C systems, ±80%. Graupner/JR, Multiplex systems need reversing (REVERSE) the throttle arm
travel! With Robbe/Futaba systems, the latter should be set to “NORMAL” = 1.5ms. The throttle trigger
should now be either at position “Motor off”! The throttle range and neutral position is fixed. You may
correct the transmitter way and neutral position on the transmitter.
3. Turn the transmitter on (position “ON”), then push the throttle lever into position “Motor off ”.
4. Connect the battery to the controller, mind the correct polarity. Plug in the power battery and try only once
to plug in. Do not touch the contact several times.
5. Switch on the speed-controller.
6. The speed controller is now ready to use
7. Move the transmitter stick forward, to drive forward. Move it backward to drive backwards.
8. After operating, switch off the speed-controller and disconnect the drive battery.
Hvala Bubizgb,probati ću pa se javim  ;)
