Topic: JR i headtracker (Read 2507 times) previous topic - next topic
JR i headtracker
Imam predatorke s headtrackerom i JR stanicu, jel ima ko kakvih iskustava sa spajanjem JR stanica na headtracker ili mozda neki vanjski modul koji bi se nakacio na stanicu?
Odg: JR i headtracker
Direktno ne ide, nije samo JR mislim da i aurora 9 i jos par, dozvoljavaju samo prva 4 kanala za trener port, a ne dozvoljavaju ch mapping tj da biras sta je na kojem kanalu nego imas TAER fiksno.
LRS ImmersionRC EzUHF ima odvojeni ulaz za HT, vjerujem i drugi.
Vidi
JR working with Headtracker...
http://www.rcgroups.com/forums/showthread.php?t=1129231
lista podrzanih, cisto za one koji planiraju
Head Tracker Radio Support. List of supported radio and instructions
General requirement for radio to support head tracking: Your RC radio must be able to selectively assign trainer functions for the higher channels (ch5-8) in order to work. Many radios can do selective assignment but only on the 4 primary controls. Read your RC radio manual 1st before requesting support for your radio.
Known Supported radios:
- ezUHF (note ezUHF supports HT independently from the radio used, if your radio does not support HT, then can add HT via ezUHF
- Futaba: in general Futaba 7 series radios and above support the HT
- Futaba T8FG (see post #123)
- Futaba 8j
- Futaba 10C
- Futaba 10cg
- Futuba T12FG (2S may trigger headset low voltage alarm)
- Futaba 14mZ (must be in 8ch mode - see setup notes in thread)
- Futaba T14SG (must be in 8ch mode and trainer switch assigned - pg 18th this thread).
- Graupner MX-12 (ch 5 and 6 only - will not support roll axis)
- FRSKY Taranis (must be setup via mixing PPM(x) as source to channel - see post #465)
- Graupner MX-16
- Turnigy 9X/ FlySky THB9
- Spektrum DX7s (latest f/w with programmable master function in the trainer menu)
- Spektrum DX8
- Spektrum DX10t
- Walkera DEVO-F4/F7, DEVO-6/7/7E/8S/10/12S
Unsupported radios:
- Hitec Aurora9
- Spectrum DX6i
- Spectrum DX7 (I've heard recent software can support this, please update if true
- Futaba 6EX
- Futaba 6J
- Futaba 7uap
- WFly 8
- Sanwa RD8000
- Sanwa RD6000
- Multiplex Cockpit SX
- Walkera radios other than DEVO-F4/F7, DEVO-6/7/7E/8S/10/12S
- Turnigy 9XR (seems to work through 3.5mm data port but due to number of problems support is no longer provided for this radio)*
Currently under investigation - please post experience
- Futaba 18MZ
- Specktrum SPM2800</blockquote>
isprobati cu thnx :)
