Topic: taranis setup za t-rex450  (Read 3095 times) previous topic - next topic
imam stari  trexa 450 flybar sa quark ziroskopom
jel zna netko neki jednostavni setup tutorial ili jos bolje .eepe file
za ustimat taranis stanicu
Odg: taranis setup za t-rex450
google  is your friend  :)
ovi .e
epe fileovi su za er9x
i kad ih otvaram u opentx companionu javlja da taj file nije za taj board valjda za taranis
http://openrcforums.com/forum/viewtopic.php?f=38&t=134
eePe files are designed to be opened either in eePe or companion9x.It 'should' be just a matter of opening them. File menu, then open, then select the .eepm file you wish to look at. It opens as a new EEPROM screen with a MODEL01 in it. You may double click on the model, then you can simulate it, or edit it.If you already have and EEPROM window open, you can drag and drop this model into it.Note: The new EEPROM window that opened will have default settings and calibration values for the General settings. It is not a good idea to program it into your tx. Read your tx EERPOM, drag this new model into the loaded window, then write the updated EEPROM to the tx.You cannot update the templates within eepe with these, they are just models with example mixes to show how they work.
rijeseno nasao eepe file uploadao i sve radi
hvala na linku  ;)
