Topic: Atas Defiance 265 quad - Swasta nesto (Read 22818 times) previous topic - next topic
Odg: Atas Defiance 265 quad - Swasta nesto
Reply #45
Mogu probat, drzi fige  ;D
InnovationMatters
Reply #46
CC3D + LibrePilot + Rate = Mrak! ;)
InnovationMatters
Reply #47
Jel imas kakvu snimku da bacim oko, bas me zanima
Reply #48
Drugi put cu ponijeti kameru pa neki video ;)
Ali nemam vise sumnji, cc3d I to je to!
InnovationMatters
Reply #49
Meni je odlican Acro+ mode na CC3D, slozio sam si jednog mini 210 i leti to je čudo ;D  na tome
Reply #50
Bas me zanima sad Libre......kakav je GCS, ima velikih promjena ili?
Reply #51
Sekile, ja sam totalno bio sumnjicav oko cc3d-a a sada ne mislim vise tratiti svoje vrijeme sa bilo kojim drugi fc-om. Stvarno radi! :)
Zed,
iskreno nisam neki ekspert te ne mogu biti siguran da ima neke znacajne promjene međutim ovo sam danas saznao I mislim da je to zaista ovako zgodna stvarcica a da covjek ne mora biti online kako bi dobio PID vrijednosti .
You can use the normal Optune for pretty close numbers (find UOV, use OPtune form...) or use the EasyTune feature embeded on LP firmware that do the same calc in live using TxPID
https://www.youtube.com/watch?v=6-CBHgDUF8A
Za frsky telemetriju sa D4R-II za 3 $, sasvim prihvatljivi nacin za citanje voltaze celija tijekom leta sa taranisom I low bat upozorenja.
http://alofthobbies.com/frsky-battery-voltage-sensor-fbvs-01.html
http://www.youtube.com/watch?v=dU-h4sJH-Tc
InnovationMatters
Reply #52
za svaki slucaj,
ovo je bilo moje pitanje na forum-u. Sadrzi video koji daje bolji uvid kako to zapravo funkcionira. Međutim ova metoda je integrirana u Libre Pilot fw I time je svojevrsna 'offline' opcija.
Today I finally found some time to burn some lipos. When I used 1.4Ah 40C 3s battery my Defiance had plenty of power and the control was crystal clear. Thumbs up for the cc3d! :)
So after confirming the build is set right and it works, time for the tune. Was reading and watching few videos and found this one http://www.youtube.com/watch?v=QqgZZ6-V3Qk.
I'm hoping that someone with cc3d tune experience could tell me is this a good way to do the tuning, any hints on what I should watch at during tune? Much obliged!
InnovationMatters
Reply #53
Ja koristim taj mali voltage divider kod sebe. Steta da si bar blize da probam to cudo, a i ti da probas kako sam ja utrimao svojeg. Cc3d je super FC, kad ga podesis radi ludilo
Reply #54
Ma biti ce neki meeting kad tad pa se cemo se naci da sprzimo par batki ;)
Sezona mi je bila ludilo balansiranja posla I razvoja a sada je posla jos vise :(, ajde barem ce biti para za nove igracke haha
Edit:
Btw, oni KingKong 6040 propeleri, prava stvar! Narucio jos par paketa danas :)
InnovationMatters
Reply #55
Vidim na Acro+ su roll i pitch factor napokon odvojeni! Pa to te pitam!
Reply #56
Napokon pronasao svojih 5 minuta danas pa iskoristio priliku malo pobilize isprobati svoj novi setup I malo bolje dokuciti karakter leta u LOS_ACRO- rate mode.
 Idealno bi bilo da sam letio bez fpv opreme ali I ovako ima pulsa u tom malcu ;)
Cisti chilling tako da ne ocekujete nesto dar mar haha
Setup:
Libre Pilot - Stock generic 250 settings
Cobra 2204 1960kV,
DYS SN20A Blheli,
CC3D-LibrePilot,
Immersion 600mW Vtx,
Sony 600TVL,
Atas Mini PDB PRO,
Frsky D4R-II,
KingKong 6040 Propeler,
Nanotech 3s 2.2Ah 35C(prvi video)
Nanotech 3s 1.4Ah 40C (drugi video).
Prvi let, zagrijavanje...
https://vimeo.com/141263840
malo kasnije...mozda malo zanimljivije :)
https://vimeo.com/141264873
Naravno da nisam ukljucio snimanje treci let bas kada sam imao dobar crash u travu, al ajde ocistio travu I obrisao propelere te nastavio letjeti tako da nije lose :D
InnovationMatters
Reply #59
eto bio bez pc-a  neko vrijeme pa ču nastojati malo kronološki popratiti priču sa mojim defiancom.
nakon par testnih letova sam zaključio da bi mi trebalo još dodatne opreme  :D :D :D
u prilogu par slikica [size=78%]....[/size]
dx7
hibrid 480 pro
defiance 285 ,micro 180
