Topic: RadioLink 2.4GHz 9CH Transmitter + R9D 9CH Receiver $68 sa KUPONOM (Read 3751 times) previous topic - next topic
Novi deal na GB
Link: http://goo.gl/n8L8NY
Kupon: GBNEWYEAR
Description:
Modulation Mode: QPSK
Spread Spectrum: DSSS
Operating Voltage: 8.6~15V
Channel Bandwidth: 5.0MHz
Operating Current: <105mA
Adjacent Channel Rejection: >38dbm
Control Distance: More than 600 meters
Channel: 9 Channel, 8~9 channel are customize
Screen: 2.8 inch 16 colorful screen , 240 x 320 pixel
Frequency: 2.4GHz ISM band ( 2400MHz to 2485MHz )
Transmitter Power: <100mw ( PCB testing ), <20dbm ( 3 meter air testing )
Simulator Model: Under the simulator model the transmitter action turn off, change to power saving model
Compatible Model: Include all 120 degree and 90 degree swash plate helicopter, all fix wing and glider, five flying model
Feature:
Adopt two-transmission technology of RadioLink AT10 10CH Radio Control, support signal strength, receiver voltage monitored and extending battery voltage, temperature, motor RPM, GPS etc
Support English and Chinese Menu
Including helicopter 8 swash plate models, fixed wing 2 airfoils 3 rears, gliders 4 airfoils and 2 rears.
Freely operating any styled aircraft
Four VR switches, three three-way switches, four two way switches, a reset trainer switch.
Support multiple aerial control mode and PTZ control
Programmable mix control. Basic menu, advanced menu, graph view for varieties of throttle and servo curve
Fast response, 3ms only, which is much less than the average 20ms even 9 channels it acts synchronously
DSSS spread spectrum mode supplies better performance in anti-interference
2.8 inch 16 colors LCD resolution 240×320 distinct and magnificent
4096 section precision, 0.25us per section, servo anti-shake rudder
Actual Measurement: Ground 600 meters, air 1000 meters
Support USB online upgrade
Vibration alarm
Kupon: GBNEWYEAR
Deal bez kupona: $74.47!
Deal sa kuponom $68.51
