Topic: failsafe ne radi!?? (Read 2475 times) previous topic - next topic
failsafe ne radi!??
znaci imam na mini quadu naze 32 plocicu i satelitski reciever. i desava se da je u cleanflightu failsafe funkcija ukljucena ali quad prilikom gubitka signala ne radi sto bi trebao nego na par sekundi vrti samo jedan motor, a trebao bi ugasit sve motore. jel itko od multi ekipe uspio aktivirat failsafe  na naze-u sa samo satelitom?   :o
Odg: failsafe ne radi!??
Nisi napisao koji je receiver, sto je u cijeloj prici najbitnije!
Sorry. Reciwer je lemon dsm2 satelit i orange stanica
Ovaj video pokazuje kako se arma failsafe na normalnom reciweru a ja imam samo SATELIT.
"Changing   failsafe   mode The   default   failsafe   method   for   all   receivers   except   the   7-channel   stabilizer   is throttle-only   preset,   with   the   setting   determined   by   throttle   stick   position   at time   of   binding. User-defined   preset   failsafe   is   currently   available   only   on   the   6   channel   DSMX receiver   and   the   8   and   10   channel   DSM2   and   DSMX   receivers.   That   mode   can   be entered   as   follows: 1. With   receiver   and   transmitter   OFF,   plug   the   bind   plug into   the   receiver. 2. Power   up   the   receiver. Note   rapid   flashing   of   the   red   LED. 3. Turn   on   the   transmitter   in   bind   mode   and   allow   the   bind   to   complete. 4. Leave   the   transmitter   ON   and   the   bind   plug in   place. The   receiver   should be   showing   a   solid   red   LED. 5. Set   the   transmitter   controls   to   the   desired   failsafe   positions. 6. Press   in   the   failsafe   switch on   the   receiver. 7. The   green   LED   will   turn   on   to   indicate   positions   have   been   stored. 8. Power   off both   transmitter   and   receiver   and   remove the bind-plug. 1 Henceforth,   whenever   the   receiver   is   powered   up,   the   green   LED   will   indicate “user-defined   failsafe   ready”.   If   signal   is   lost,   the   receiver   will   output   the   preset positions   after   approximately   3   seconds   and   maintain   them   until   a   signal   is received   again. Be   sure   to   test   failsafe   operation   by   turning   off   the   transmitter   (be   very   careful   if you   do   this   with   a   live   power   system   – preferably   remove   the   propeller!). To   return   to throttle-only   preset,   simply   rebind   the   receiver   normally"
citat iz manuala za lemon receivere
http://www.lemon-rx.com/shop/documents/Lemon%20RX%20manual.pdf
na kraju dokumenta se nalaze upute za failsafe
